1997 to 2003 F-150
Old Mon, September 28th, 2009, 09:52 PM
Default Rear end vibration on a lifted truck.
I have a 7.5" Fabtech lift on my truck with a 5" block in the rear. Before the lift I could drive it at any speed without the vibration. Since the lift and the 4.56 gears I have a vibration at about 80 mph. I've had the gears replaced once because of a faulty ring and it still does it. Is this going to be the norm or is it something that can be corrected? Maybe the u-joint or out of balance driveline? Any thoughts?
Old Mon, September 28th, 2009, 09:59 PM
fordkindaguy's Avatar
fordkindaguy fordkindaguy is offline
Wanna go fast
fordkindaguy is on a distinguished road
My best guess is that you probably have off road tires and they are not balanced correctly. With larger tires this is common.
Old Mon, September 28th, 2009, 11:29 PM
Good answer!
Also this Is the pinion angle set at the proper pitch with the use of shims or tapered block? If this isn't done you will start to go through ujoints also.
I have seen tapered blocks put in backwards an upside down along with shim wedges forgotten.
Just some ideas!
Old Tue, September 29th, 2009, 10:39 AM
It isn't a tire issue because its not that kind vibration. The blocks are tapered and are impossible to install upside down because of a pin and hole in the top and bottom of each block. I'm going to replace the u-joint and see if that helps.
Old Tue, September 29th, 2009, 12:02 PM
theSLEEPER's Avatar
Love Games?
Do you have a carrier bearing? If so, you might want to drop it down a little. If not, you might want to see if you can space the transfer case down a bit. I don't like getting too much tilt on the rear diff...
Old Tue, September 29th, 2009, 12:29 PM
Wanna go fast
make sure to replace your yokes while you do the differential!
