Old Fri, October 2nd, 2009, 03:54 PM
Rustler Rustler is offline
mad cow member
Rustler is on a distinguished road
Default Custom tune issues?
I started my own post so I wouldn't hijack the other gentleman's post with the same problem.
I've been running the canned level 2 since I received the Gryphon. On my truck this wasn't near the improvement over stock others mention though there was a slight improvement. This made me quite anxious to get my custom tune in hope there was more performance to come.
I received my custom 87 performance tune 9/30.
I drove it 85 miles thinking to myself something aint right here. The new tune feels like stock performance with perfect shifting. I programed it to the level 2 canned tune, canned level 2 is more powerful feeling with so so shifting.
I tried stock VS the new custom 87 tune, there appears to be no difference in performance though the shifting is night and day better using the custom tune. I re installed the custom tune due to the vast improvement in shifting. So far 140+ miles on the custom tune.
I am quite disappointed with the custom tune.
Hopefully there is a remedy.
Level 1 custom 87 perf.
Level 2 canned tow.
Level 3 canned 93 perf.
07 F150 screw, 5.4, auto, 4x4 esof, lariat.
Gryphon with 87 performance custom tune.
275/65/20 dura tracs, 2" AS - 3" block, true duals with h pipe to flow pro dido, ugly arsed tips pointed in a funky fashion.
Old Fri, October 2nd, 2009, 04:42 PM
ROtested's Avatar
ROtested ROtested is offline
ROtested is on a distinguished road
I appreciate you calling me a gentleman as I frequently get called worse on a daily basis!!! I notice many, if not all of the same things as you, particularly, the power on canned level 2 feels noticeably higher than the Custom 87 Perf I have.
Since originally posting I have gone through a lot of fuel testing the various tunes, hoping that I was doing something wrong and the canned level 2 is still far and away the best I have noticed so far. The stock and Custom 87 Perf tune shifting on my truck are both very lethargic. On both, I can punch it, run it up there in speed in 2nd gear, let off the gas before it shifts to third to coast and drink almost a whole cup of coffee, while I am coasting, before the truck finishes shifting down to OD!
On the canned level 2 the shifting is very firm out of the box, so i was running a -5 on all shift firmness settings which worked very well for me. While playing around today with the tunes, Custom 87 perf required a +10 on the shift firmness to be in the ball park of the canned level 2 on -10 shift firmness, but, canned level 2 feels noticeably more powerful.
Old Sat, October 3rd, 2009, 12:13 PM
JWBFX4 JWBFX4 is offline
Well I definitely have to say something doesnt sound right with yalls tunes. The best advice I can offer is try to get in touch with php so hopefully yall can get this worked out.
Old Mon, October 5th, 2009, 04:31 AM
John,
As I mentioned to Greg, try running the truck in "stock" mode for an hour or so and then retry the performance program. Sometimes the PCM learns a bit far in one direction and needs some time to settle back in to a "normal" type of mode.
If this doesn't work, I'm certainly happy to revisit the calibration and make any adjustments necessary.
Keep me posted.
Old Mon, October 5th, 2009, 12:49 PM
mad cow member
I appreciate the suggestion. I'll give it another try.
I have to say I don't understand. Before I made the post or e-mailed Corey I did try stock for about an hour and 40 miles then the custom tune for about the same for back to back comparison. Besides the shifting aspect there seriously appears to be no other performance difference. Any time I reload canned level 2 I can feel a slight performance improvement though the shifting suffers verses what the custom tune provides.
I now have about 160 miles on the custom tune.
I'm in the Seattle area on business right now, it will have to wait till the end of the week.
Thanks, John
Old Mon, October 5th, 2009, 05:31 PM
John,
If you've already tried the stock method with no results, then I'll definitely look into the files. I just wanted to make sure we eliminated a PCM learning issue before going any further into it.
I'll get a look at the calibrations in the next day or two and will have an update available by the end of the week for you. Just check the [Update Status] in Pegasus for a later release date (after 10/05) for the calibration on the server.
Take care and have a safe trip.
