Old Tue, November 3rd, 2009, 04:50 PM
F-One-Fiddy F-One-Fiddy is offline
F-One-Fiddy is on a distinguished road
Engine starting issues after reseting to stock settings
Afternoon all,
I recently ran into a problem with my Edge tuner that I hope some of you advanced guys may be able to shed some light on. I currently have an 05' F150 5.4L FX4 with a CAI and cat back exhaust. After having my edge installed and working as good as canned tunes can work for 8 months, the screen on my edge went blank . I had the edge set for towing mode (to help offset the lean air/fuel mixture until I could save up for a gryphon and custom tunes). Thinking that the cable could be the issue I stopped and parked my truck and began playing around with the cable. The cable will probably need to be replaced, but when I was attempting to reset back to the factory settings the screen would go blank (but still be backlit), change colors, or randomly shut off when I had to turn the key off to let the PCM be reconfigured. After several attempts of returning the tow mode back to the original factory settings mode I was finally able to get everything to reset (or so I thought) . After things had been reprogrammed back to factory I went to start the truck and the engine turned over once...paused and then eventually started. I have since had to start it 7-8 times (driving to/from work) and the same problem persits. My best rookie guess is that some parameters from the factory settings have been changed and are causing this issue with starting.
Has anyone experienced this before? Any ideas going foward?
Im planning on sending my edge to the guys for the gryphon upgrade with custom tunes once they get back from SEMA.
Sorry for the long post, i was trying to paint a picture of the problem at hand.
Thanks for any help......
Old Tue, November 3rd, 2009, 05:04 PM
JWBFX4 JWBFX4 is offline
Well I have never had that one happen, but I do know that Edge has some good customer service and they can probably help you. Plus if your cable is bad then you would go thru edge anyways for a replacement.
But I also think one of the worse things you can do (meaning by stranding the vehicle) is if you think you have a bad cable and continue to try to program. Because if it goes out in mid session I would assume you would need help to get back to running.
Old Tue, November 3rd, 2009, 05:17 PM
I know we are pretty advanced here but since it looks like it may be a bad cable or connection and its still an edge evo that's who I'd be calling right now!!!!
Bill could have helped you out but as the notice says they are at SEMA. So to keep from doing anymore possible damage to the pcm programming I would contact Edge right now!
Did I happen to say contact EDGE right now?
Old Tue, November 3rd, 2009, 05:30 PM
Once I noticed the display screen had went blank on me (and after reading a former post on here about bad cables) I wanted to immediately switch back to factory settings to keep me from being stuck with a truck programmed by an unresponsive edge.
It looks as if the cable was pinched in the pod and eventually wore through after ~8 months of vibration. I will contact edge tonight to discuss a new cable and other possible causes.
As for the engine...The cranking is the only problem (known as of right now). After the engine starts up, all the gauge needles remain in the pre-ignition position (all on the left side of the gauges in what would be the off position). The needles on all the gauges shake (vibrate slightly is a better description) for about 5-6 seconds after startup, then all come to life and all is fine until I have to restart the truck again. Then the whole procedure starts again.
The truck runs normal, but there is obviously an underlying problem here.
Thanks for the help so far...
Old Tue, November 3rd, 2009, 06:06 PM
I agree, there's an underlying problem and none of us are smart enough to figure it out! I'd think a corrupted tune would effect more than starting. And, what you describe DOES NOT quite sound like a weak battery, unless the cranking seems slow, does it? If it does, get the battery load tested.
Old Tue, November 3rd, 2009, 06:34 PM
If you figure that you can't get immediate help from edge and want your truck to be reliable. I really don't know what edge could do for you besides sending you a new cable and you will have to wait for it. Then edge can work their magic and get your pcm back to a stock tune.
You may have to take it to a dealer or someone that can reflash your pcm to a un corrupted stock tune. This is only if you are having cable problems.
BTW The past cable problem that happened was for the 1997-2003 f150 models.
