Old Sun, November 22nd, 2009, 08:57 PM
Default What makes an Economy tune?
Is it increased SOI, ICP, decreased PW, or all of them, and how much?
I would assume lower shift points, earlier TCC engagement, and a "softer" low boost fuel map but I am just shooting in the dark here.
Old Sun, November 22nd, 2009, 09:10 PM
Shooting into the dark and just about hitting a bull's eye. How's that for lucky?
Very little on all accounts of SOI and ICP. PW can be whatever you want once you get above a certain ICP since you don't really care about economy once you get above 2000 PSI or so.
I would increase SOI a degree or two at the most below 1600 or 1800 RPM and at low fuel rates. ICP can ramp up a little more aggressively but again, you're trying to go for economy.
All in all it boils down to your right foot. THAT'S it.
Old Sun, November 22nd, 2009, 09:50 PM
Ok.......well its pretty hard to control the right foot sometimes, but if I had a tune that could do it for me that would be pretty nice.
Would lowering the entire Mass Fuel map do this?
So by increasing ICP and lowering PW you will not gain any MPG results, thinking better atomization?
The SOI increase I understand but it is kinda weird to think about everything all at once, (this affects that, and that changes that).
I love it
Old Sun, November 22nd, 2009, 09:56 PM
Well in all actuality, commanding an increase in ICP does have an indirect "advancing" property to it as well.
As far as lowering the entire MFD map......yes and no.
You can lower the values enough to give a dead pedal.
Another idea would be to lower the fuel limit for RPM map and set the low boost fuel map to give the desired result and still be drivable. It's a balancing act.
I'd just put an egg on the accelerator pedal.
Old Sun, November 22nd, 2009, 10:20 PM
And the plot thickens
Would just increasing the ICP be enough to get better MPG's, or should it be accompanied with a slight increase in SOI?
I understand lowering the fuel limit stuff, but trying to understand how to make the engine more efficient on its own, without my negative influence.
The egg might not be a bad idea tho......
Grrr....damn touch screen, gotta be careful around these things.
Old Sun, November 22nd, 2009, 10:28 PM
Just increasing the Desired ICP table does little. It's a function of MFD and RPM. So.....
What I said before about a balancing act with the MFD map becomes a little more clear.
Yes, the Desired ICP map can be increased in those areas where you wish for a little more efficiency. Before you get too excited about asking for 1500 PSI where there was previously 700, there will be a point where it becomes a bear to drive; we don't want that. Also the benefits will start to diminish at some point.
On a side note, those ICP-fooling devices like the Workhorse module and Edge Juice actually DO work. They command an increase in ICP and mileage does go up. They wreak havoc on the HPOP, but they do give you a decent power increase with some mileage if driven decently.
