Old Fri, December 4th, 2009, 09:11 PM
oasis04's Avatar
oasis04 oasis04 is offline
Jet Driver
oasis04 is on a distinguished road
Default couple of questions
I recieved my little package today.
Do I need internet access to load the chip or are the basic tunes on the cd?
second Let me hear your configuration strategies and why? ie...#1stock #2drivethrough #3High idle ......and so on?
Thanks in advance.
Jeff
Semper Fi!!!!!!!!!!!
'97 F350 CCLB SRW 4X4 ZF5
DIY 6637 intake
FPR shim
3" down pipe 5" straight pipe 7" stack
PHP 6 pos chip
pillar pod 3 gauge (fuel pressure, EGT, Boost)
08 Console
Nitto Terra grappler 295/75/16
Old Fri, December 4th, 2009, 09:32 PM
FU will require internet access to load the selected files to your chip burner.
Configuration strategies.....
Ha, mine change every time I drive the truck. Reason being is that if the emulator (for live tuning) isn't being used on someone else's truck, it's near-permanently installed in mine.
Old Fri, December 4th, 2009, 09:57 PM
oasis04's Avatar
Jet Driver
Additional question How and where do I get the activation code?
Invoice 2427
Jeff
DIY 6637 intake
FPR shim
PHP 6 pos chip
08 Console
Old Fri, December 4th, 2009, 09:58 PM
I'll alert Corey and Bill so they can get you hooked up with POWAH!
Old Fri, December 4th, 2009, 09:59 PM
oasis04's Avatar
Jet Driver
That would be awesome I know they are nocturnal creatures.
Jeff
DIY 6637 intake
FPR shim
PHP 6 pos chip
08 Console
Old Fri, December 4th, 2009, 10:08 PM
oasis04's Avatar
Jet Driver
Heres another question. Can I set this up on my lap top also? or will it all be keyed to one puter?
Jeff
DIY 6637 intake
FPR shim
PHP 6 pos chip
08 Console
