I recently sent my Edge tuner in to be transformed into a Gryphon because of my exhaust & intake additions to my '07 f150. For the past two weeks now I've been getting the P061B error, Internal Control Module Torque Calculation Performance. I got the error 3 times within the last two weeks. When the error arises the truck enters failsafe mode with the wrench lit up on the dashboard. Any ideas?
Tried calling but no answer so I will try again later.
Thanks. |
Here's what my DTC library from Auto Enginuity gives me..... P061- HO2S Heater Resistance(bank 2, sensor 3) System Grouping: Fuel and Air Metering And Auxiliary Emissions controls
Antonio '01 F-250 6spd 2wd Handshaker 7.3L PSD Stealth Dual Hpops, AC Alliants Headstuds and Forged rods balanced DIY Regulated Return with Racor Filtration #54 GTP 38R out 4" exhaust Southbend Con OFE to get it to the ground Gauges...Boost, Pyro, Fuel Pressure and temp.,HPOil, EOT, Pre and Post CAC temps I'm sure some other stuff I forgot! |
On aboutautomobile.com I found that the DTC for P061B is Powertrain: Internal Control Module Torque Calculation Performance. Maybe there is a difference because of the "B". Thanks for info.
Alternatively, you MAY be able to program your PCM in Level 1 (transmission only) and get away with it. Level 1 in the canned tunes is supposed to do nothing more than firm up your shifts, which might be better than nothing! It won't hurt to try. - Jack |
