Go Back   Power Hungry Performance Forum > The Starting Point > Latest News
Latest News
Stay up to date with what's going on.
Old Wed, December 23rd, 2009, 05:18 PM
STATE INSPECTION ADVISORY FOR GRYPHON/EDGE OWNERS
Recent threads and posts are indicating that some of your trucks are going in for state inspections.
If you do the following you'll have a better chance at passing.
1. There should be no need to put the truck back to stock level 0.
2. Simply unplug and remove programmer and cable and go to test station.
If the above aren't followed and you put your truck back to stock level 0 you'll get a p1000 code and won't pass.
If you think you need to have the truck tested with stock programming than do it a week before and drive at least 50 miles before going to the test station.
P1000 FAQ Link:
http://forum.gopowerhungry.com/faq.p...50_drive_cycle
Thank you
Have a Good One!
Old Tue, March 9th, 2010, 10:23 AM
eagle1highlander eagle1highlander is offline
eagle1highlander is on a distinguished road
Default eagle1
What state or states are we talkin about?
Old Tue, March 9th, 2010, 10:55 AM
shotgun's Avatar
shotgun shotgun is offline
Gryphon CTS
Any state that has emissions testing and/or connects to the ODBI or ODBII port as part of the testing.
Old Tue, March 9th, 2010, 11:40 AM
If your State or locality (in Arizona we have two "localities" - Tucson and Phoenix) requires an emissions inspection, you'll know about it. If you've never heard of this inspection, I doubt it's required where you live.
I wonder if I'm the only one who doesn't seem to get the P1000 code when I switch back to stock though? I ALWAYS put the truck back to stock whenever I take it in for service, even an oil change, and I've NEVER seen the P1000 (or any other code).
Old Tue, March 9th, 2010, 12:24 PM
Come to think about it now?
I don't think I have ever seen it pop up when I go back to stock either.
Hmmmmm........
Interesting.
Old Tue, March 9th, 2010, 12:34 PM
And, I THINK the Gryphon will "see" and display a P1000 code? Makes you wonder, doesn't it?
Old Mon, October 8th, 2012, 03:15 PM
Chris Chris is offline
Chris is on a distinguished road
Default Hounddawg007
I live in California, and I had a similar problem with stock Edge program. I was running a little lean due to other mods, so I cleared codes and went to stock. When i went to test station they saw I had cleared codes so that would be an automatic failure for smog. I had to put over 100 miles on truck to get this to clear from computer.
