Old Sun, January 3rd, 2010, 05:58 PM
ballisticmike ballisticmike is offline
ballisticmike is on a distinguished road
Default question re: display of COM GEAR
well my gryphon works awesome. I love the improved shifting!! I have not encountered any operational bugs at all.. so far so good. Also too soon to determine if gas milage improves.
I was setting up my display to show ECT, EOT, LOAD and COM GEAR.
Well com gear does not show up in that menu at all, i scrolled up n down several times. Is it unavailable ?
Old Sun, January 3rd, 2010, 06:45 PM
No its there, I think it's on the bottom of the list...or at least somewhere down there. That is one of my four.
Old Sun, January 3rd, 2010, 07:16 PM
F150 Man 4Eva F150 Man 4Eva is offline
Hidden Valley
F150 Man 4Eva is on a distinguished road
One of my four as well.
Old Sun, January 3rd, 2010, 09:53 PM
arg, i just scrolled thru (twice) and counted the displays listed ... i have
21 display options, the gryphon manual shows there 22 weird.
Old Sun, January 3rd, 2010, 10:03 PM
Hmmm, that is strange. Try finding it in another place. When you are at the main menu go to diagnostics>data stream options then see if you can find the COM GEAR by selecting a PID. If its not there then you should probably talk to Bill.
Old Mon, January 4th, 2010, 10:27 AM
The firmware hasn't changed in forever and all the PIDs should be in there. Here's the list...
Engine RPM
Vehicle Speed
Engine Coolant Temp
Engine Oil Temp
Trans Fluid Temp
Cyl Head Temp
Intake Air Temp
Line Press Desired
Actual Fuel Rail Pres
Output Shaft Speed
Turbine Shaft Speed
Mass Air Flow
Mass Air Flow Volt
Variable Cam
Spark Adv
Torque Control
Engine Load
APP Sensor
BatteryVolt
Inst MPG
Avg MPG
Commanded Gear
Check and make sure that your firmware is version 3.02.0639. If it's not, you'll need to update the firmware.
Let me know.
