Old Thu, January 7th, 2010, 03:06 PM
MercedesTech's Avatar
Default Update ?
Hey guys. long time no talk. Hope all is well !
Trying to do some updates. Trying to update pegasus, but when I apply updates it gets to updating file structure.edf and will freeze. Will not load anything past this.
Am I doing something wrong ? I should be updating pegasus, correct ? Will not hurt my custom tunes ?
*** now it says
unable to locate file structure.edf
This is usually caused during server maintenance or when files on the server are being updated.
So, try again at a different time or... ???
"In the beginning of a change, the patriot is a brave and scarce man, hated and scorned.
When the cause succeeds, however, the timid join him...for then it cost nothing to be a patriot."
_ Mark Twain
Old Thu, January 7th, 2010, 03:18 PM
alright making some headway ! (I think... lol)
Looks like everything uploaded. Not sure how well...
Now it is asking for me to fill out the registration (yes, this is my first update, what can I say ? haha)
When I go to help, then click on registration and it says:
Run Time error '713'
Class not registered.
You need the following item to be installed on your machine.
MSSTDFMT.DLL.
getting closer... maybe...
_ Mark Twain
Old Thu, January 7th, 2010, 03:38 PM
Lastly, is there a safe way to update the gryphon ? Do I need to ? Without messing up my custom tunes...
_ Mark Twain
Old Thu, January 7th, 2010, 07:17 PM
Help
bump before I head home.
_ Mark Twain
Old Thu, January 7th, 2010, 10:02 PM
If I were you, I'd completely uninstall Pegasus (and try to clear the Registry of any Pegasus entries too), then reinstall it while following the install instructions on PHP's web site. I'm guessing you have Windows Vista? If so, you MUST be very careful to follow Bill's installation guidance.
If you have Windows 7, I don't have any pearls of wisdom to offer, sorry!
Old Thu, January 7th, 2010, 10:51 PM
Dont worry about your custom tunes. As long as your vehicle was programmed to stock you'll have no problem there. Pegasus will most likely warn you that you will lose your custom tunes. Unless you are a special case where Bill had to email you the tunes simply go to the [Target Functions] and your custom tunes will be reloaded.
