Old Tue, January 27th, 2009, 02:41 AM
glockwinger's Avatar
glockwinger glockwinger is offline
Glocks and Goldwings
glockwinger is on a distinguished road
Idea for Gryphon display
Bill,
Thought of an idea that you have probably visited over the years, but I thought I would throw it out there::fuel:
Normally I use the 4 parameter display. Sometimes there are other things that I want to see while driving that requires me to have to change the settings. For instance: if I have RPM, EOT, ECT, and TFT all displayed and I want to see Fuel economy, Air Intake temp, accel pedal position, and Torque converter locked/unlocked...I would have to reprogram all those things into the display (DO NOT DO THIS WHILE DRIVING! obligitory disclaimer )
What if you could set up two pages that could be accessed by pressing the up or down arrow to go between two sets of displayed parameters? Maybe someone wants two different settings for towing and performance and could toggle between the two having them set up in advance between page one and page two? You could have the some of the same parameters on both pages or completely different.
Don't know if it is even feasable, but it is something I have wondered about...:ideaon:
Thanks for reading!
Glockwinger...a.k.a. Phil from Minnesota
"All that is required for evil to prevail is for good men to do nothing" - Edmund Burke
Old Tue, January 27th, 2009, 09:31 AM
That's a great idea! Now, is it possible? (Bill has certainly gotten a lot of mileage out of the basic unit, hasn't he)?
Old Tue, January 27th, 2009, 09:33 AM
Member in Sin
That is a good idea.
Old Tue, January 27th, 2009, 12:15 PM
That's not a bad idea at all... just one hitch. The up and down arrows are already tied to the dimming function of the LEDs and the Enter button is tied to resetting Avg Economy.
I've thought about setting up the Enter button as a "Quick Menu" and that might be a solution, but I'd need to figure a way to enter both sets of displays and then how to toggle them.
Always something fun, eh?
Old Fri, January 30th, 2009, 01:03 AM
ClearBlue's Avatar
ClearBlue ClearBlue is offline
Forge
ClearBlue is on a distinguished road
Default Radio Button Displays
Bill,
Just a quick note on toggling from screen to screen; could you use the double click function that was used on the 1.0 Attitude for toggling screens?
If you could use that function for toggling, then you could set up a [ ] Second Display radio button in the “Display” menu. When entering the “Second Display” menu, you would have a duplicate of the “Setup Digital Displays” which would instead say “Set up Second Display” with a radio or toggle button to enable the second screen. Other than that it would be the same procedure for setting up the second display as it was for setting up the main display.
Just a thought,
ClearBlue
BTW: An introduction is probably necessary for the group. I worked with Bill at Edge Products and was responsible for setting up the hardware for the Attitude 1.5 and implementing the base menu system. I am now on my own preparing to launch a start up business focusing on fuel Economy – Just a note as to who I am. Thanks for reading my post.
Old Fri, January 30th, 2009, 11:21 AM
Sounds like a good possible approach, ClearBlue! Welcome to the forum. Any friend of Bill's is a friend of ours.
Old Sun, February 1st, 2009, 12:29 PM
Originally Posted by ClearBlue View Post
Bill,
Just a thought,
ClearBlue
Glad to have you here! It's always nice to have knowledgeable people around.
Thanks for the advice on that. The menuing on the display settings you described I'd had in mind already, but the double-click function might be a cool way to activate the alternate displays.
I was also thinking about a "Quick Menu" from the enter button which would display "Reset Avg. Econ", "Toggle Main Display", and maybe 1 or 2 other functions quick functions. Haven't laid it all out yet, but just assimilating data at this point to see which would be the easiest to implement and the most useful.
