Go Back   Power Hungry Performance Forum > Ford - All Other Vehicles (Disabled) > 1994 to 2020 Ford Cars
All OBD-II vehicles go here. Mustangs, T-Birds, Cougars, Taurus SHOs, Contours, Focus, Mark-VIIIs, GTs, and anything else you can think of will be right at home.
If you have questions about late model cars or just have a nice one to brag about, here's the spot for you, too!
Old Thu, April 22nd, 2010, 10:31 PM
bsdracing bsdracing is offline
bsdracing is on a distinguished road
Default turbocharging 2001 ford focus lx 5spd
wondering what tuning and size injectors and if mass air is a must to turbo a stock 2001 ford focus its one of my two focuses and just needs more power like my cummins and powerstroke lol what do you guys think? I have turboed mustangs and stuff like that but all used blow through carbs. can i simply make a oil feed and oil return in pan and put bigger injectors and some tuning? or would I need mass air cant remember if it is already or not.
Old Tue, April 27th, 2010, 08:15 PM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
Being a 2001 yes it is mass air. Honestly for the power you will produce a 65 mm TB and 19 lb injectors will work. When tuning get your AF ratio and MAF transfer function right and you will be good. For that car I wold bump up to a 190 lph fuel pump also. Everyting you can get from a bone yard.
Chuck
1995 Mustang GT
2004 Explorer Limited
Old Sat, May 8th, 2010, 12:47 AM
so pretty much just make feed and return oil lines and bigger fuel pump mess with some tuning and thats it I have turbocharged carbed motors before just nothing with a computer lol
Old Sun, May 9th, 2010, 05:39 PM
ChuckD's Avatar
Yes make sure when you plumb your tubing you blow through the MAF and have your blow valve set to 7 psi.
Chuck
1995 Mustang GT
Old Mon, May 10th, 2010, 08:49 PM
alright thanks a ton I will see what I can fab up with the stuff I have also is it true I cant tune a focus with minotaur? I once again have not looked into the PCM on the focus but could it be tuned with a chip?
Old Mon, May 10th, 2010, 09:50 PM
ChuckD's Avatar
yes you can use the chip. I am pretty sure that you can use the Minotaur. Also in your exhaust make sure to put an extra bung for an AFR guage, so you can monitor that. I would look for a turbo from a 90 Probe.
Chuck
1995 Mustang GT
