Old Mon, April 26th, 2010, 11:36 PM
Default Scaling?
Whats the deal with changing scaling values?
Here is my 3-4 shift over stock, when the pointer is at the 500 A/D counts the stock shows as 300 A/D.
I have more questions about this with my ICP map, but we will start here.
Old Mon, April 26th, 2010, 11:40 PM
Guess I could add this too..........
Old Tue, April 27th, 2010, 10:46 AM
I guess I don't understand what you're asking.
Each "pointer" or dot has to represent a real value. You have ten of them to play with and each one of them has to corellate to something. For example, based on the "shape" of your graph there, I could also make the truck shift very similar to stock just by doing this:
Old Tue, April 27th, 2010, 11:44 AM
I understand what you are saying..............maybe I was just expecting a different result.
Old Tue, April 27th, 2010, 11:58 AM
F-127's Avatar
F-127 F-127 is offline
Tuner novice
When you're comparing functions, seems like the software will compare based upon the pointer value. Like Cody said, you've got a few to work with, and stock tunes don't always use them all. They are not necessarily a point of equal throttle position or MPH in this case. Comparing point 6 stock to point 6(your tune) isn't really a fair comparison being both X and Y are different. Comparing point 6 stock to point 4 would be OK, but you're not going to see it on the bottom of the screen. If you want to compare your point 6 to stock you could draw a vertical or horizontal line. Looks like at 500 A/D it the stock shift was about 2.5 MPH lower, as you probably see. So whats that feel like, well if you were cruising along at 55MPH, you now only have to push down the throttle to 500 A/D to get a down shift when before you would have had to push the throttle to the 570ish range.
Hopefully this helps. If it doesn't that's OK, I think I learned some things myself to explain it.
Hey Cody, I see you have an updated signature. That's awesome!
Thomas H.
Old Tue, April 27th, 2010, 12:24 PM
Thanks Thomas.
OK now to my next question.
Why in the ICP map on few of my programs the MFD only goes to around 44, when others go to 70?
Old Tue, April 27th, 2010, 12:33 PM
That is what your last tuner did. Why? I couldn't tell you for sure. What you could do is rescale those to stock with the normalizer FN013 and try it........
I don't see the reason for doing what they did.
