| Upgrade your Evo (Disabled) Upgrade your Edge Evolution to a Gryphon Programmer to allow for custom tuning and additional functionality. Due to issues with the cable failures due to incompatible versions of firmware, we do not offer upgrades or tuning for the 1997-2003 F-Series gas or 7.3L diesel trucks. We recommend using another platform. |
Hi, Just wondering if you guys can make more power with your tunes over the edge tunes?
Some people say to upgrade the injectors and upgrade the evolution.Currently while towing on the extreme level we get some smoke but the pre turbo EGT's are not too high at all (1000 deg) at 25 psi boost. This 97 f450 has an early 99.5 turbocharger and 6.0 intercooler,edge evo,intake and exhaust work,LUK single mass flywheel/clutch upgrade This truck is mainly used for towing so we don't really want any smoke while under load.The edge extreme tune smokes and doesn't make as much power as we thought it would have. |
The problem is two-fold.
First off, the injectors are very "small". This means that the actual amount of fuel they can inject during one power stroke is minimal. So your ultimate power potential isn't very high (which is why your EGT stays cool). Secondly, the compressor on the turbocharger doesn't move very much air (even though it's a later unit). Thirdly, the high pressure oil pump isn't up to the task of moving very much oil for very long. The largest gains will be in the shifting....not so much the power although we can eliminate a large amount of smoke.
Tuning, PCM flashing, and burning chips for 7.3s since 2008. Repairing all aspects of 7.3L Powerstrokes for 25 years. Eight 7.3L PSDs in the driveway including a 1994 Crown Vic and 1973 F100/2002 F350. Looking for the next victim. |
Thanks for the reply.So I guess Will could run into issues if we only upgrade the injectors.I was knid of thinking that the turbo would be on the outer limits when this truck is uesd for towing most of the time.Also who Knows if the orignal HPOP is up to the task fo upgraded injectors/chip.
Thanks again for your honest opinions. |
