Old Fri, June 4th, 2010, 06:55 PM
majek5's Avatar
majek5 majek5 is offline
Nothin' Stock
Default PLEASE HELP! HIGH EGT'S!
Anybody know why my egt's are 1000-1350* while towing the toy hauler, OD is OFF. The tralier is about 10,000#. With a free flowing exhaust and tymar, and adrenaline, something is not right! Please help before I go . BTW, this is using my heavy tow tune.
'06 6.0 F350 CCLB KR.
stock...
Old Sat, June 5th, 2010, 01:15 AM
my trucks all run 1000 to 1350* EGT while pulling heavy on hot days, except my 2000 F550 after I put 90cc single shot injectors in it, now it have a hard time getting 1150* EGT. With the stock split shots it would get to 1400* EGT, with a 4" turbo back and a 6637 intake.
Is your '97 a California model? dose it have split shots? IMHO split shot make hotter EGTs then singles
Jay 413-222-8286 I got hay for sale
'97 F350 CC, DRW, pickup, 7.3, E4OD, 2wd, 4.10, 405K
'00 F550 reg cab, 11' flatbed, 4x4, 7.3, 6637, 4R100 (soon to be a ZF6), 290k
'97 GMC 5500, getting a transplant, 3.36, sleeper, 350k
Abolish the Federal Reserve, They are the #1 problem.
www.prisonplanet.com
Old Sat, June 5th, 2010, 01:17 AM
hi EGTs isn't that what piston coolers are for??
Old Sat, June 5th, 2010, 02:08 AM
Have you checked for boost or exhaust leaks yet?
Old Sat, June 5th, 2010, 11:57 AM
majek5's Avatar
Nothin' Stock
Nothing is loose or obvious as far as either go. Since I have no cooler, the only boost leaks would be from the y pipe into the motor, right? As far as exhaust leaks, is there way to check besides looking and listening?
stock...
Old Sat, June 5th, 2010, 03:22 PM
Boost leaks can include the turbo outlet o-ring, intake boots, intake manifolds or any combination of the three.
Looking for the exhaust leak is the easiest way to tell, you will see the soot around the problem area.
What are your boost #'s when EGT's are high?
Good Luck
