Old Thu, June 10th, 2010, 06:36 PM
gogriz2009 gogriz2009 is offline
gogriz2009 is on a distinguished road
Default help wanted
Looking to buy my first chip. It seems after researching since may that I have found what I want. I was just wondering if you guys could give me a heads up on any unsuspecting issues i could run into. also any help with the ordering would be apprecited. I guess I should tell you I am putting this in a 02 excursion. Thanks for the help.
Old Thu, June 10th, 2010, 07:00 PM
The only real issue we have with the Phoenix on Excursions is the PATS anti-theft system. Without being able to read the Vehicle ID block from the PCM, we have no way of enabling the PATS system with a chip.
We can either program a chip and you live without PATS (the "Theft" light will flash unless you unplug the PATS module...no big deal) or you can send us the PCM, we'll read it, then make programs using your original VID block. We don't like disabling the anti-theft system if we can help it, so we prefer you ship us the PCM.
Old Thu, June 10th, 2010, 09:00 PM
So bypassing the pats would mean what exactly. Just no alarm? The wife drives this rig so how would you unplug the pats. i know she wouldn't want any flashing lights. I can't ship the pcm to you as it is the kid hauler right now. Thanks for the help.
Old Thu, June 10th, 2010, 09:01 PM
By the way---where is reed point? I am in Florence just below Missoula. Small world.
Old Thu, June 10th, 2010, 09:30 PM
I figured by your user name that you were from Montana.
Go CATS!! HA HA
By disabling the PATS system, the vehicle will start even if the ignition lock cylinder is broken into and turned with a screwdriver....it's just an anti-theft system. The PATS system will keep the engine from starting unless the correct key is used.
I am currently in Georgia working for PHP doing 7.3L tuning. I'll be going back home in September for the winter. Reed Point is about 60 miles west of Billings on I-90.
Old Thu, June 10th, 2010, 11:10 PM
MtPaul401 MtPaul401 is offline
MtPaul401 is on a distinguished road
Go Cats
Man, and here I was telling people how helpful and knowledgeable you were.
Old Thu, June 10th, 2010, 11:38 PM
HuckA1A's Avatar
HuckA1A HuckA1A is offline
HuckA1A is on a distinguished road
Go CATS!! HA HA
I don't believe that Bill and Corey will let you leave.
Huck
early 99 (11/98) F250, PSD, auto, 4x4, ec, short bed.
6637/wrapped by Pete, CCV Mod, 6.0 Trans Cooler, MKO 4", '05 Power Seats, PMT2, Transgo Tugger,DP-Tuner F6, diy oba, Isspro Performax, pyro, boost, Engine oil Temp and Trans temp gauges, Truetrac rear, diy coolant filter, '02 Headlights, Terminator modded 17 hpop,
