Old Sat, July 31st, 2010, 11:16 AM
Default Failed COPS
I've had my Gryphon since early this year and Bill spent some time with me getting my truck up and running after an engine swap. Since then I've had 4 COPS fail on me. Could this be a tune issue? It hurts spending $45 every 2 months on the same issue and it's never the same COP. Can I adjust something to help the issue?
Old Sat, July 31st, 2010, 04:54 PM
Put OEM plugs back in it.
Old Sat, July 31st, 2010, 05:13 PM
I has motorcraft plugs in it. I don't use anything else.
Old Sat, July 31st, 2010, 05:37 PM
Hard to see how a tune could effect a coil.
I imagine heat could be an issue - wonder if they run too hot in the re-worked environment? (I admit, I'm reaching on this.) Are the COPs OEM, or are they a different brand?
Old Sat, July 31st, 2010, 05:43 PM
Were they ever changed before the engine swap?
If the plugs were not changed in regular intervals they can weaken the already weak coils.
Old Sat, July 31st, 2010, 09:53 PM
The old motor's COP's were changed as needed (about one every year or so).
The new motor's COP's were changed after a month or so after I got it swapped. They were changed to new OEM's from old OEM's.
Old Sat, July 31st, 2010, 10:57 PM
Like Jack said, tuning should not have any effect on the life expectancy of the coils.
If spark plugs were always changed when needed and coils were replaced with OEM's then the only reason for the failures would be normal wear.
