Old Fri, August 6th, 2010, 01:51 PM
BigSur BigSur is offline
Scientist
Default GOT 'EM!!!!
Guys, just received installed my 87 performance tune. To put it simply, I love it......very satsified
I have a few follow-up questions if you don't mind, and I apologize in advance if there is some redundancy from previous inquiries:
- Does Bill personally load in TS and GR in the custom file? If so, do these become the NEW placeholder values? In other words, if I assume he did enter these, would I lose HIS entries if I don't "load previous settings" the very first time I go into custom programming? I skipped it the first time just to see how the truck drives. I really need to go in and check TS and GR but need to know if I need to load previous settings the first time in.
- Secondly, is it normal for O/D to NOT kick in until a higher speed is hit.....is this a characteristic of a performance tune? Either my TS is really off....or it's the tune, b/c I can't acheive O/D until about 50mph, which before it was easily acheived around 43 mph. Honestly, I'm hoping it's a characteristic of the tune. I like it...a LOT, although it might hurt my economy. I drive a TON of 35 and 40 mph roads around my city, which causes a lot of unnecessary shifting in and out of O/D, so a lot of the time, I take O/D off. As it is now, that has been fixed unless the reason being is my TS is off.
Thanks in advance boys!!!!!!
Old Fri, August 6th, 2010, 07:30 PM
Bill USUALLY sets your TS and GR in your custom tune. But, if you open those things in Custom Options, you will NOT see his values! So, the best thing to do is check the Gryphon speed PID against a GPS or check your dash odometer against a measured distance like interstate highway markers - the longer distance the better. Then, there are numerous threads here that talk about how to correct if needed.
The Custom Options menu is NOT a facility to "check" on what values are loaded. It is used to set new values. Please see my Q&A on this confusing feature: http://forum.gopowerhungry.com/faqs-...ions-menu.html
I suspect Bill set your OD to come on and lock up at the higher speed. That is normal for a "performance tune".
Old Fri, August 6th, 2010, 07:50 PM
Scientist
Gotcha. I read that you can't load previous settings the first time in, so if I access those items in the menu, I will immediately see placeholder values, correct?
So for TS, I will check it with a GPS first. It it's accurate, I'll just leave it alone. The main reason I wanted to check is I've got a sweet spot number that put me almost dead on over a 180-mile ride. I was hoping I could check what Bill entered to see how close his number is to mine.
That's what I was hoping to hear on the OD b/c I like it. Thanks Jack, as always. Have a good weekend. I'm heading to Cabo San Lucas as we speak. You've been a lot of help to me in the past 2 months, so I will drink one especially for you
Old Sat, August 7th, 2010, 09:25 AM
The tire size is completely dependent on inflation pressures, speeds, and manufacturer tolerances. We can usually get close given a tire size, but there will almost always be a need to correct it once the Gryphon is installed in the vehicle.
Old Sat, August 7th, 2010, 11:11 AM
As Cody said, there are factors that will cause errors. Your plan to check things as they are is sound. If you find there is an error, go ahead and reload your tune with YOUR TS value and DO remember to check and adjust the GR too, if necessary.
You did good to load the tune first without opening Custom Options.
Old Sat, August 7th, 2010, 12:46 PM
Scientist
Appreciated guys. Thanks for the input
