Old Fri, August 27th, 2010, 02:11 PM
jerry edwards jerry edwards is offline
jerry edwards is on a distinguished road
Default EGT HIGH
My Egt is as high as 1425 in stage2 and towing a 44ft box trailer in stage1 as high as 1450,my truck is a 2002 F250 7.3 4X4 with a 5' exhaust,KnN Air Kit, and a Gryphon Programmer.
Old Fri, August 27th, 2010, 05:05 PM
You probably have a exhaust leak at your turbo y pipe. Pay the money and get the international pipes. I can send you a DIY link. I replaced mine with donuts and will have to do it again soon. The pipe wears out and not even a new donut will fix it. Take a look and see if you got any black around it. The pipe near the turbo was leaking. My exhaust was pulling on the turbo.
Old Mon, August 30th, 2010, 10:13 PM
Default EGT High
I checked and i don't here a leak.Send me the link i'll check it out,if you don't mind.
Old Tue, August 31st, 2010, 03:40 PM
Welcome to Pocket's International UP-Pipe Replacement Web Page
Make sure you check out his main site he has a lot of DIY links for our truck. According to cleatus you won't here any leaks. You only leak under boost hence the high egts while towing etc. More and likely your going to leak from the upper y pipe connecting to your turbo. Take it from me don't waste your money and get the replacement seals get the international pipe. I will direct cleatus here so he can give his opinion.
Old Tue, August 31st, 2010, 04:05 PM
How heavy is the trailer? What RPM are you running while the temps are that high? 4th gear or 3rd? Any hills?
Old Wed, September 1st, 2010, 02:29 PM
Default Egt High
My trailer is about 9000LBS loaded.Going from a dead stop at the to end of first gear (3300 rpm) at 55mph it hits 1450 EGT.On a smaller hill on the highway in 3rd gear at 3200 rpm it hits 1425,i only run the truck with O.D off there are alot of hills on the way to the track.
