Old Tue, August 31st, 2010, 09:53 AM
Stu_486Fitter's Avatar
Stu_486Fitter Stu_486Fitter is offline
Stu_486Fitter is on a distinguished road
Question Timing/Octane question
I read in a previous post http://forum.gopowerhungry.com/2004-...-program.html? that if you are running an octane level other than the one specified for a tune you should retard/advance timing. Im kind of clear on it but just want to be sure. Im running 87t canned tune but always run 93 octane. BTW its a 06 5.4 if it makes a difference
Old Tue, August 31st, 2010, 10:49 AM
First, I have to ask: "Why are you using the 87t tune if you're burning 93 octane gas. Are you towing?" If so, then yes - go ahead and advance the timing. You should be able to set it to +3, but I'd start with +2, since your engine is most always "under load" when towing. If you notice no problems, try setting it higher, to +2.5, then +2.75 and finally to +3.0 if things seem OK.
If you're NOT towing, you should really be using the level 3 91+ octane canned tune. In that tune, with 93 octane gas you MAY be able to set the timing to +1, but I'd do it in stages (+0.5, +0.75, +1.0), checking for problems at each step.
Old Tue, August 31st, 2010, 10:57 AM
Sorry. Probally should have been more specific. Using 87t because i am waiting on custom tunes and have a CAI. Have recently switched to 93 because it was having issues(prior to tunes) and the higher octane seemed to help
Old Tue, August 31st, 2010, 12:14 PM
What issues? If you're having issues at stock, don't expect canned or custom tunes to fix them.
Old Tue, August 31st, 2010, 12:31 PM
Not expecting tunes to fix. At WOT with 87 octane the motor would break up a lil bit and the CEL would flash as if it was a miss but wouldnt record a fault. Was suggested to me to use a higher quality fuel with a higher octane, and it runs beautifully now. Note: that was happening AND was cleared up before the tuner was ever in play. Now I always run 93 and want tuner adjusted accordingly untill i receive my custom tunes.
Old Tue, August 31st, 2010, 03:49 PM
No - You're not understanding what I meant. Your truck was designed to run on 87 octane gas. It should do that just fine as long as there's no underlying problem. Fixing it by burning 93 octane gas is like putting a bandaid on an oozing sore - the infection's still there, but you don't see it.
Why did you get a power loss at WOT? Just a guess, but perhaps you hit the rev limiter - which causes an immediate "cut out" to prevent damage. Why don't you get this using 93 octane? You might, if you advance the spark to take advantage of the anti-knock properties of the fuel. Right now, your spark is retarded for the fuel you are using and you probably develop LESS power at a given throttle setting/load than you did using the 87 octane gas. This means the truck will not pull as "hard" as it did with 87 octane, since the "burn" is not coming at an "optimum" time in the piston's power stroke.
