Old Wed, February 18th, 2009, 03:28 PM
Jon Roseman Jon Roseman is offline
Jon Roseman is on a distinguished road
Default Whats the difference in tunes?
I have an 06' 5.4L with aero 3030 exhaust, 3 in leveling kit, AF1 CAI. I was wondering what the custom tunes do exactly? Are they just messing with the setting I can customize on my performance setting already or are they more advanced than that? Either way I don't know enough about it to customize my own as far as timing, shift firmness, etc. Also, I wanted to know if anyone has any advice as far as making my own setting on performance canned tune. Bill, I will be requesting some custom tunes either way but just wanted some information.
I would appreciate any help!
thanks,
Jon
Old Wed, February 18th, 2009, 04:52 PM
thanks,
Jon
You COULD be running lean with the CAI if you're using canned tunes. That's one thing Bill can adjust for in a custom tune. What else? Well, what altitude do you normally drive at? What is your average outside temperature? Are you pulling anything besides what Edge thought was a "standard" trailer?
He can adjust line pressures to the transmission that you can't. He can adjust the fuel map much more precisely for your needs than what you get with the canned tune. I suspect, but don't know for sure, that the dynamic timing curve can be manipulated in ways you don't have access to.
According to Corey, there are over 100 parameters that Bill manipulates to give you a custom tune. And, he has years and years of experience at this business.
Sure, you can do a "few" things. Things like increasing your WOT RPM, WOT shift points and normal shift points. You can change your timing, gears, tire size and shift "firmness", and a few other minor things, but that's about all.
Oh, and welcome to the forum, Jon!
Old Thu, February 19th, 2009, 03:25 AM
Once again, Jack is on the case!
There is much more to custom tuning we provide than just twiddling the "custom options" that come on the programmer. Those options are there to allow customers to make some "fine tune" adjustments based on parameters that are often subjective as specific to a persons tastes. This is especially true with shifting characteristics.
Tuning for a CAI or exhaust is done generally to eliminate the resultant lean conditions these modifications often introduce. In many cases the lean conditions are manageable by the ECM, in some cases they are not. It depends on the specific components, ambient conditions, fuel quality, and other factors.
Given the modifications you indicated, custom tunes are surely the way to go... even if it's just 1 or 2 programs. Most often, people will find a good program that fits their needs and just stick with that. Others, like enthusiasts, may switch from program to program as the situation demands. It all depends on what you're looking to achieve.
I hope this is helpful.
Old Thu, February 19th, 2009, 05:20 PM
Ya, that helps considerably! I'll be sending in an application for some tunes shortly. Thanks for the input, Bill. Anyone got any experiences with adjusting their shift points or anything I can do while I wait for my tune?
I was also wondering what kind of gains I could expect from a 93 octane economy custom tune because that is all I run in my truck now that I got the gryphon and I don't want to change octane ratings all the time.
Thanks,
Jon
Old Thu, February 19th, 2009, 08:15 PM
Sburn Sburn is offline
Jon
Starting from the canned 93 - Performance tune, here's some of the little tweaks I've done. Note that I have a 4.6, not a 5.4.
Octane: -2 counts becasue I don't use 93 or 91 octane gas.
1 -> 2 Upshift +2 MPH
2 -> 3 Upshift +10 MPH
The 2 -> 3 upshift change made the most difference to me. Seems like my 4.6 is just starting to get its legs as it revs up in 2nd.
3 -> 4 Upshift +5 MPH
I changed the corresponding down shifts to match the above.
Left all T/C locks/unlocks alone, but I might adjust this after I drive as above for a while and when things dry out in CA.
Shift firmness: +2 on 1 -> 2, +5 on 2 -> 3 and 3-> 4.
I don't expect to adjust RPM limit since my butt dyno tells me the stock 4.6 is past the torque curve much after 4500 RPM.
I left speed limit at facory 95 MPH. Darn few safe places to go faster than that. Plus factory tires are crap for those kinds of speeds.
Like it says in the manual, make small changes.
Also, try to only change one thing at a time so you'll know what works and what doesn't.
Keep notes, because if you do make small changes and one at a time, you'll be making those changes over weeks and not be able to remember what worked good and when.
Old Mon, February 23rd, 2009, 12:56 PM
Thanks for the input man! Anyone have a 5.4 and notice a similar setup with positive outcomes?
