Old Sun, January 16th, 2011, 11:52 PM
KIRT KIRT is offline
KIRT is on a distinguished road
Default EXTERNAL MEMORY REFLASH?
Plugged my gryphon in today and it told me the external memory needs to be reflashed. What does that mean....What happened? My truck has not been reflashed nor has it even been into the shop. I was still able to drive my truck using the last saved tune i'm guessing...I dont run the gryphon plugged in all the time so i am not sure if I may have screwed somthing up through pegasus....the last thing I did was change the splash screen. I do not recall if it worked after that....it has been a while since i plugged it in. Any thoughts?
2007 F150 XLT 5.4L: 3" SISO MAG: VOLANT CAI: GRYPHON TUNER
Old Mon, January 17th, 2011, 12:10 PM
I've never seen this!
So, you changed the splash screen while the truck was still "tuned" above stock? That should not have hurt anything as far as I know.
Once you get past that message, does the Gryphon seem to function normally? Or, does it keep you from getting past that message? AND, we're talking about the monochrome Gryphon and not the CS/CTS version, right?
If it's the monochrome Gryphon, did you have the ignition key ON before you plugged the Gryphon in?
Old Mon, January 17th, 2011, 07:31 PM
Yes it is the original Gryphon. It wont let me past the message and the key position is as it should be for start up.
Old Mon, January 17th, 2011, 07:38 PM
This is exactly what it says...The external memory needs to be reflashed call tech support at (678) 963-9913.
Old Tue, January 18th, 2011, 11:24 AM
Kirt,
Bill is working his tail off right now getting through support issues and service tickets. It may be a little bit, but he IS getting things taken care of.
Old Tue, January 18th, 2011, 08:04 PM
Kirt,
Corey e-mailed me saying that pegasus had a bug and was fixed yesterday...I updated as suggested and the problem still exists.
