Old Sat, January 29th, 2011, 09:31 PM
hampsterzone's Avatar
Come Get Some
Default CAI indepth.....
I have heard many arguments on CAI. Gotts mod, CAI, ect. Well, a very good friend who is a mechanic of 25 yrs, gave me the low down. CAI's are the best for adding horsepower. The Gotts mod is cheap and effective but not as much as CAI. Moving the MAF sensor doesn't cause lean codes. It reads air flow no matter where it is. Lean codes come from custom exausts not CAI. Low back pressure cause the lean codes. Which makes sense cause I never had a lean code with my edge and CAI alone. But when I did headers and true dual exhaust I saw lean codes on bank #1 and bank #2. We did find that the Gotts mod is the cheapest, easiest mod you can do. But again, it is in my opinion that it depends on what you want and how much you are willing to spend. Hope this helps. Oh and by the way, removing cats could be the worst thing you could do as far as causing our engines to run lean. I am not an expert but my friend has worked on many F150's and says they are great trucks to modify if you take your time and do it right. Thanks guys.
2nd place is 1st's loser!
Old Sun, January 30th, 2011, 07:55 AM
DarkShadowSTX's Avatar
DarkShadowSTX DarkShadowSTX is offline
DarkShadowSTX is on a distinguished road
I have always read that the reason you get lean codes is because you move the MAF.
Backpressure is supposedly just a myth. I never had a lean code with my EDGE and CAI but I did get other codes because the truck wouldn't run correctly since the CAI changed the MAF location. Custom tunes on my Gryphon fixed that. A lot of people with EDGEs and 5.4Ls got lean codes with CAIs though.
Old Sun, January 30th, 2011, 11:58 AM
Come Get Some
Yeah, it seems to be a complex system that varies upon application and truck setup. Idk, but I can say that if you are going to do mods you better be prepared to do them right. Thanks, I appreciate everyone's opinion. As far as the MAF and exhaust causing lean codes. Probably both! I do believe my mechanic on the exhaust though. Not sure if I believe MAF being the reason. More like more air from the CAI. I am sure we will figure it out soon enough.
Old Sun, January 30th, 2011, 03:05 PM
If your wanting to add power, a blower is the best. A CAI can't compete with boost.
The CAI's are slightly more effective at increasing power because of the slight lean condition they cause. I've seen 30 horsepower on a dynoed mustang just by going from slightly rich to a leaner A/F ratio. The ratio was then tuned back to stoic out of conscern for the motor.
Those horsepower numbers that the companies advertise also is not across the entire power band. That is the peak horsepower marks. Below about 2200 rpm you could have an intake the size of a trash can but the engine will not be bringing in any more air than it was before.
The commercial "cold" air intakes use a larger diameter pipe than the stock sensor housing.
This is a picture that demonstrates what a cross section would look like. The blue area is what the truck calculates for and the red area is what is not calculated because of an aftermarket intake that is larger than the stock housing.
The MAF sensor in these newer trucks is a heated wire. As the engine pulls in air the wire is cooled by the "breeze". The resulting temperature of the wire increases or decreses its resistance to electrical current which is read by the computer. With the larger diameter, the air will flow at a different speed. If you were to bring in 60 grams/sec of air it will flow faster in the narrower tube. Higher air speed, lower wire temperature.
On a stock truck the sensor is calibrated for the stock fluid area (blue). Any result you get from the MAF sensor can be calculated into an accurate physical volume. If you increase the diameter, you change the air speed, you change the reading and in doing so, you change how much air an electrical value represents. This is where custom tunes come in and we've got plenty of threads about that. :thumbup:
So the sparknote version:
Yes, the MAF sensor will read airflow no matter where on the intake track it is located, but that does not mean the reading will be accurate.
When you increase the diameter of the pipe the air does not need to move as fast to move the same volume. The slower air velocity will read on the sensor as the wire being slightly warmer, making the resistance slightly different. When the value is different the truck fuels different.
The gotts mod does not have this issue because it does not impact the MAF sensor in any way. All the gotts mod does is allow more of the shielded fender air than the stock system.
Old Sun, January 30th, 2011, 04:50 PM
Come Get Some
Excellently put! I appreciate your response. Any thoughts on exhaust causing the O2 sensors to relay lean conditions?
Old Sun, January 30th, 2011, 05:09 PM
ticopowell's Avatar
Grown-up in training!
My question about the CAI's and the MAF is that on the 2 K&N CAI's that I have installed, the MAF sticks around, and so did the pipe surrounding it. here is a picture here is another
the pics are for different sensors which may or may not be different than what we have, but my point is the same. That specific diameter where the MAF is located stayed the same in my trucks where I put in a CAI versus stock because that piece, even though it moved up or down the intake track, was exactly the same diameter.
The only thoughts that I have that would make it different is that if the pipe or filter right in front of the MAF made air flow faster through the pipe where the sensor cant read, such as the other side of the tube, then there would be a lean condition.
any thoughts?
Old Mon, February 7th, 2011, 06:07 PM
The lean codes from the o2 sensers can be atributed to a vacuum leak occuring after the maf up to the point of combustion......after combustion the exhaust may cause these but before the o2 senser if there are......broken welds, broken header studs, cracked manifolds, bad gaskets.......
