Old Mon, April 11th, 2011, 03:26 PM
wood4heat's Avatar
wood4heat wood4heat is offline
wood4heat is on a distinguished road
Default Pro's & Con's Gryphon vs. Phoenix + Edge Insight
I have been set on the Gryphon CS since joining this site but some of the things I've read have me concerned. Mainly that something could go wrong when switching tunes leaving me out of commission. I still like the idea of all my gauges in one neat package as well as some of the diagnostic abilities and think I may have come up with a compromise. What do you all think of running the Phoenix chip with the Edge Insight?
I can see benefits to being able to change a tune on the fly but wonder how these two would work together. Do you get the same level of tuning with the Phoenix as the Gryphon?
Also can the Phoenix compensate for oversize tires?
I wasn't sure if I should put this in the Gryphon or Phoenix forum. I figured since it's going on a 2003 7.3 it would fit here and users of each platform could share their thoughts.
Thanks!
Old Mon, April 11th, 2011, 06:13 PM
ticopowell's Avatar
Grown-up in training!
I can't answer all your questions on this one, but I do understand that you can have both the phoenix and the insight at the same time. I don't know though if the phoenix can adjust for tire size. If it can, it can be tuned for the tires and then if you change sizes you will have to purchase new tunes. Also Bill's tunes are the same across all his platforms, so the phoenix can have the same ones as a Gryphon.
Hope I helped.
Old Tue, April 12th, 2011, 01:11 AM
wood4heat's Avatar
Hope I helped.
That's what I would think. Even though I'm interested in the Phoenix I wonder how you can order off the menu with the FU chip but need all pertinent info from your truck to tune the Gryphon. Seems like you would get a higher level of customization.
Is it just because he writes Gryphon tunes to work with your ecm programming and chip tunes simply replace the existing program? If that's the case do chips have a shorter lead time?
Oh and you did help!
Old Tue, April 12th, 2011, 01:42 AM
ticopowell's Avatar
I think the phoenix somehow replaces the ecm so you don't need to know what tune you have... but I could be wrong, I have been before. I dont think though that this will change the wait because he will still customize the tune to you and your specific truck, plus he works on orders in the same order that he recieved them.
Glad I could help
Old Tue, April 12th, 2011, 10:30 AM
widieseltech widieseltech is offline
widieseltech is on a distinguished road
Default chip
i have the gryphon cs tunes by bill tunes are great if your not going to go crazy with mods then i would get a gryphon cs, for me i wish i would have got a phoenix chip now because when i bought it i was only planning on doing a chip, exhaust and intake. now i have a chip, intake, exhaust, regulated return, garrett gpt38r, im planning on doing stage 1 single shots. so a 6 pos chip would work better for more customizable tuning in my opinion. If your looking for a gryphon cs i'd maybe sell you mine.
Old Wed, April 13th, 2011, 07:35 PM
Instead of the Edge Insight - You might want to look into this: UltraGauge Automotive Information Center and OBDII Scan Tool
I don't know if it will work in your truck, but at the price they are quoting, and for what it can do, I'd sure find out.
Then, the Phoenix chip is a VERY good choice for your truck to get better performance. And yes, it does magical transformation on the ECM that works "on the fly" and other neat things that the Gryphon can't do. I think it is way cheaper, too.
