Old Sat, April 23rd, 2011, 03:33 PM
Cory S Cory S is offline
Cory S is on a distinguished road
Default Did i fry my chip???
i have the FU burner and chip and have reburnt my chip 4 times with no problems. then today i went to update tunes and it says my software is out of date, so i went on and downloaded the new pheonix software. but now after i select tunes and the pop up says place in position 1, i press ok, and an error comes up that says the chip is not formated. it says check in utilities and see if the multi chip authorization s FC but mine is FF.
2000 Powerstroke (PMT1)
4x4 auto XCSB
Old Sat, April 23rd, 2011, 07:51 PM
bump bump bump
4x4 auto XCSB
Old Sat, April 23rd, 2011, 08:36 PM
ticopowell's Avatar
Grown-up in training!
If this should be in the "truck wont work/emergency/stranded" section then you might expect Bill to respond on a weekend, but if it does work then they probably wont respond until monday. if it is an emergency I would call though, it would make things go quicker than waiting online.
I would try and help but I don't know anything about the FU chip or the FU2 chip. :/
Old Mon, April 25th, 2011, 07:44 AM
Check your burner power relay. Over-zealous installation of the chip into the burner can dislodge the relay and cause you this exact problem.
Old Mon, April 25th, 2011, 02:38 PM
i checked that and it is intact where is should be
4x4 auto XCSB
Old Mon, April 25th, 2011, 04:52 PM
If your relay is in fact where it should be, your switch is in the first position, and you are getting "FF" for CID, it's likely that it's fried.
