Go Back   Power Hungry Performance Forum > Ford Super Duty & Excursion > 1983 to 1994½ 7.3L and 6.9L IDI (Disabled)
Got one of those old mechanical injected 7.3L or 6.9L trucks? This is the place for you!
Old Fri, March 6th, 2009, 10:53 AM
kokopellimotorsports's Avatar
addicted
Default Who has?
Who has modded an IDI truck and what have you done? Just curious.
Ty
2001 Dodge Cummins
Tuning is addicting. Lol.
Old Fri, May 1st, 2009, 11:18 PM
John Anderson's Avatar
John Anderson John Anderson is offline
John Anderson is on a distinguished road
I have done a few of them. I actually have one coming in Tuesday morning for fueling and timing adjustments on the dyno. I will post up the mods and dyno sheet from the last one I did when I get to the shop tomorrow. (if I remember, lol)
Old Fri, May 1st, 2009, 11:29 PM
addicted
I would appreciate that, thank you.
Ty
2001 Dodge Cummins
Old Sat, May 2nd, 2009, 01:58 PM
I remembered! The truck I did was a 94 IDI with a factory turbo. We installed new stock injectors and lift pump to cure some performance problems. For more performance we turned the fuel adjustment screw 4 flats and increased the timing by 4 degrees (aprox., my pulse adapter had died). I was pretty impressed with results. Stock the truck did 110 hp and 290 torque peak. Modified peak was 210 hp and 409 torque.
Old Sat, May 2nd, 2009, 11:31 PM
addicted
That is impressive, I think I will be playing around with my cousins IDI. He has the ATS turbo on it, with some really leaky injectors.
Ty
2001 Dodge Cummins
Old Wed, May 6th, 2009, 07:10 PM
Have another one coming in on Friday. I will post up the before and after dyno sheets along with the intial and final fueling and timing settings.
