Old Tue, June 7th, 2011, 01:05 PM
pohlmeyr pohlmeyr is offline
pohlmeyr is on a distinguished road
Default Bigger Tires = New Tunes?
I just put some 295/75/18 tires on my truck and wasn't sure if needed to get new tunes?
I feel the shift points might need to be adjusted
2008 5.4L F150 Screw, MBRP exhaust, Green Filter!
Old Tue, June 7th, 2011, 01:27 PM
No you can adjust the tire size through the custom options menu when ever you reprogram. Try entering 2750 as your tire size and see how close that gets you.
Or the best thing to do is to program a value you know is incorrect like 2600. Then if you have a GPS going clear both it and your odometer and drive at least 15 miles. Then do this little formula:
GPS odometer/truck odometer x the tire size you just entered (2600). The number you get is your actual tire size.
Old Thu, June 9th, 2011, 11:49 AM
Use the custom options menu to change also double check the gear ratio...
Old Sat, June 11th, 2011, 07:45 PM
bikerfuzz's Avatar
bikerfuzz bikerfuzz is offline
trapped in the city
bikerfuzz is on a distinguished road
Default size
so would the same apply if it was a 295/65/18? Its still an 18? Thats cause I just out my new tires on too. So under greate custom option hit yes? and just fix the tire size to ??? and hit yes thats it.?
Old Sat, June 11th, 2011, 09:07 PM
No, a 65 series tire has a much different diameter and circumference than a 75 series tire. Longshot gave you 2750 for the 75's, I would have suggested 2730, but that's a small difference that might be good "boundaries" on the values to try. If you've installed a 75 series tire, start with a value between 2750 and 2730.
If you are using 65 series tires, they are not nearly as tall (but they're "fatter"). Try something between 2580 and 2560mm.
You would enter these values in the Custom Options Menu - Tire Size.
Old Tue, June 14th, 2011, 01:33 PM
bikerfuzz's Avatar
trapped in the city
Ok. I'm going to try. But why the range ? Is it to get as close to actually displayed speed?
