Old Mon, June 20th, 2011, 09:02 AM
SubVet SubVet is offline
SubVet is on a distinguished road
Default Theoretical ¼ mile times
Ok, I am sure this question has been asked a 1000 times (I’ve tried searching but couldn’t find anything). I was wondering what type of ¼ mile times would my truck run? I have no intentions of running it, just curious.
My truck: 99 ecsb 4x4, 4r100, late 99 motor, early 99 suspension, PHP FU chip, 4” exhaust, Airaid intake, AIH delete, 05 front end, 265/75/16 tires, wicked wheel, deleted pedestal, ebpv delete, 93K, HPX, 3.73
Assume running it on the race tune
Old Mon, June 20th, 2011, 09:10 AM
Funny you asked this just now.
I ran on the strip Friday night. Although I didn't run a "stock" tune down the strip, I did run one that should be in the 60-80 HP range and it did a 16.7 at 84 MPH. However, that's in a regular cab 2wd truck with a lot of off-the-line tire spin....your results will vary with a 4x4 Supercab.
Old Mon, June 20th, 2011, 10:50 AM
cj45lc cj45lc is offline
sounds like someone needs some slicks
Old Mon, June 20th, 2011, 11:11 AM
Slicks and a locker. The factory limited slip is just that...."limited".
Old Tue, June 21st, 2011, 02:27 AM
I betcha he would be in the mid to low 15's with a boosted launch.....that 60' time is what really sets the pace for the rest of the run.
Old Tue, June 28th, 2011, 02:15 PM
A stock-tuned regular cab with a standard launch should be in the 76 MPH range at the 1/4.
A crewcab shortbox would be in the 73 MPH area.
A supercab would be somewhere in the middle.
Your truck should be in the 83-85 MPH range. ET depends on traction off the line in that case.
Old Wed, July 13th, 2011, 08:23 AM
God & Guns
It seems with my truck (not sure if the description is correct, added wicked wheel, PHP custom tunes, and 6637 filter) a boosted launch isn't as quick as punching it off the line. With a boosted launch, it seems like it takes longer/higher rpms to change gears. When punching it off the line, the gears just fall through nice and smooth. I can build about 10psi on a boosted launch before breaking traction.
Old Tue, August 2nd, 2011, 11:50 AM
qtrhors qtrhors is offline
qtrhors is on a distinguished road
my wife went 15.9 at 82 mph in our truck. track elv 500 ft 80^ day. This was 8 yrs ago. She would powerbrake into boost and launch in 4wd then switch to 2wd. I told her after 3 passes....that be enuff or we wont be able to tow our low 12 sec mustang home(could drive it but no AC and cruz control for 1100 mi is a pain lol)
01 F250 Lariat PS 7.3 auto SB CC 4x4
old superships microtuner, 285/75/16 Cooper Discoverer ST's, Aero straight thru stainless steel muffler, Access tonneau cover
