Old Tue, July 5th, 2011, 06:51 PM
DarrenWS6's Avatar
Default Traded in '04, have '07 Lariat, swapping Gryphon to new truck questions.
Hello there folks, I've been a stray the past few months, well big stuff has happened. Part of that big stuff is I traded in my old '04 XLT Supercab for a '07 Supercrew Lariat. Kept the wheels/tires and Gryphon. Of coarse returned the 04 to stock. I want to add it to the '07 but have some questions.
Firstly, what all will I need to do to get it changed over for the new truck in a '87 tune? Send in an application stating what I want? I already have the old programmer and all. Hex and Serial # available of coarse.
Second, Should I do the minor performance modifications first? I am only planning a DWV intake mod and chopping the OEM Y pipe for a Magnaflow #10778 Y pipe which basically eliminates the restriction of the OEM pipe, and to run a single 3" pipe to a 3" Borla muffler and 2.5" tailpipes.
I also plan to add on the 33"x12.5"/20 Mud Terrains I had on the old truck to this one but am kind of scared to for the rear end and transmissions sakes. The gears are 3.73 open, not LSD unfortunately, old truck was 3.73 LSD. Will it move fine? I also feel that aside of my 'hot doggin driving' as seen in some of my Youtube videos.. ( ) that the transmission in my old truck developed a minor slip. I don't plan to whoop on this truck and it has barely ever towed so I am hoping that the trans in this truck will handle 33s on 3.73s fine? I had heard that the 04/05 3v 5.4Ls were mated to a 'weaker' transmission than what is in the '06/'08 trucks, is this accurate? I am hoping so. Stock to stock, this 2007 Lariat seems A LOT quicker, actually very much, than how my 2004 felt, and almost equivalent to how smooth and quick it moved tuned on 33s. I have about figured out what I want in a tune for this one so I hope it will work.
Advice for all of my question areas? Greatly appreciated.
Also, are the tune return times about the same as they were in '09/'10? ( 1 month or so? )
And also how about adding an update for a modification, say I do exhaust and order the tune, 5 months later I do the DWV mod, will it cost me the price of a tune to update my file?
And a couple pics of my new truck.
Trade in day.
Old Wed, July 6th, 2011, 09:26 AM
Nice looking ride
All of the mods you listed can be done before or after your custom tune, they really aren't tune dependent .....
Here's the order form ....just list anything and everything.....no different than from before....>>>https://fs21.formsite.com/Power_Hung...m45/index.html
Old Wed, July 6th, 2011, 09:43 AM
DarrenWS6's Avatar
Nice looking ride
Thank you. So the DWV increasing the intake inlet to 3" isn't a tune necessary change? Is that because the MAF is not altered?
Old Wed, July 6th, 2011, 09:50 AM
Right.....you keep the stock air box....so the transfer location remains the same
Old Wed, July 6th, 2011, 10:33 AM
And, as long as you've restored the canned tunes to the Gryphon, [Updates]->[Gryphon Update Manager] in Pegasus (update both the firmware and calibrations) you can use the Gryphon in your new truck right away.
I'd recommend the Level 2 tune.
Old Wed, July 6th, 2011, 06:02 PM
DarrenWS6's Avatar
Okay, so that is basically how I "clear" the old file? And it will be canned and ready for the new truck, well thats good, i'll give it a try in a few minutes.
So the Level 2 tow tune will be safe for daily driving? Mostly is a canned tune for more low end energy correct me if I'm wrong?
