Old Sat, August 20th, 2011, 11:55 PM
eej711's Avatar
eej711 eej711 is offline
eej711 is on a distinguished road
Default Can a tune be written for economy on the HWY?
Can a custom tune be written for specifically HWY driving, like when I take trips and drive 200+ miles on Interstates? Or is the Custom performance tune just as good?
Old Sun, August 21st, 2011, 10:50 AM
Custom performance is usually the best tune for highway driving but it varies from truck to truck and the conditions. If I plan on doing a bunch of driving over 55 mph I'll switch to my performance tune just because it has better passing power. Mileage for me is usually the same regardless of tune as long as I'm not having to get heavy on the gas pedal.
Old Sun, August 21st, 2011, 12:54 PM
eej711's Avatar
So for city driving is performance not the best when there are a lot of stoplights since you said you will switch to performance for HWY?
Old Sun, August 21st, 2011, 02:24 PM
usually a towing tune seems to be better for city driving. The towing tune is designed for getting the big heavy truck to get going with a load, and it does it well without a load as well. So because city is stop and go, and you need to get the truck moving from a stop multiple times so it seems to do better, but like Longshot said, it is all up to your foot on how good of gas mileage you get.
Old Sun, August 21st, 2011, 03:22 PM
That is correct for my truck and tunes. BUT every truck is different and every custom tune is different. One reason the tow tune works better for me in the city is that I have highway gears (3.55 LS) and larger than stock tires. This combination works against me because due to gear ratios I am at a mechanical disadvantage. I like the tow tune for stop and go because the extra torque helps to overcome this disadvantage. My tow tune is also written with a pedal position map that is less aggressive than stock (for off road use) so the truck is not as jumpy.
Old Sun, August 21st, 2011, 08:18 PM
Longshot has just posted a very well written comment about how you should look at tuning.
You have to tell Bill EXACTLY what you are looking for in a tune. And, you cannot assume he will understand when you say something like, "highway economy". I know that seems enough to many people, but it really does not fill in the "picture". For instance, what are the distances driven on the "highway"? Is it an Interstate? Where are you driving and what are the conditions (elevation?, hilly? speed limits?, temperatures?). What does your truck weigh when it's being driven this way? Do you have any mods like a bed cap that change the aerodynamics? Do you need passing performance?
I suspect there are other things that might go into this, but the goal is to put Bill into YOUR "driver's seat" so that he can set things up the way he would if he were you, looking for what YOU want. It's not easy, trying to mind-read a customer wanting custom tunes. Try to remove that obstacle and you'll be happier.
