Old Mon, September 19th, 2011, 10:30 AM
God & Guns
Default Removed the red line from wastegate solenoid
With my low boost numbers, I tried running the truck without the red line plugged in. I just pulled it off and crimped it in place with a zip tie. It now holds higher boost than usual while accelerating but I'm still only getting 21psi. So still hunting that problem. My question is, is there any harm keeping the red line unplugged? I've heard some peolpe saying they lost mpg, but I'm not sure if that actual hand figure of the over-head display?
Old Mon, September 19th, 2011, 11:58 AM
Nahh, your fine. Just keep an eye on the boost levels, stock turbo is not too happy above 25(ish) psi.
Old Mon, September 19th, 2011, 12:17 PM
God & Guns
Yea, I'm getting 21psi at WOT. Still like to get that other 4. Thanks
Old Mon, September 19th, 2011, 12:38 PM
So what is the point of doing this? I hadn't heard of it until now...
Old Mon, September 19th, 2011, 03:24 PM
God & Guns
Well, if I'm understanding the operation of the wastegate solenoid, .... when boost gets so high, the PCM sends pressure through the red line to the waste gate solenoid pushing on the backside of the spring...which allows the wastegate to open. Taking the red line off makes the wastegate open just by drive pressure, without assistance of the PCM. Thats what I worked out in my head from a little reading and looking at the system. So someone please correct me if I'm wrong.
Old Mon, September 19th, 2011, 03:31 PM
I just talked to cody, I think you are basically correct. I have a general understanding now, but not enough to explain it to anyone lol
