Old Sun, February 26th, 2012, 02:39 PM
God & Guns
Default Power locks not working
My power locks have not worked in the 3 yrs that I have owned the truck. The key fob and communication works. The fob nor the door switches will work the locks. I pulled fuse 26 I'm the power distribution box to check it and the truck turned off. Put the fuse back and I was able to start the truck. One of the legs of the fuse looked burned but the element seemed to be intact. I believe I replaced the fuse a couple of yrs ago and the looks seemed like they didn't have enough umph to actuate. Every time i tried to work them it seemed like they were getting less and less juice each time.
When I talked to Bill, he told me Cost was the expert on this issue.
Old Sun, February 26th, 2012, 04:46 PM
cj45lc cj45lc is offline
Mine got to where they would work but were real weak & then it got to the point that you could hear them trying to work but just wouldn't get it done. I went ahead & got the new lock actuaters from Ford for about $35 a piece & everything has been fine. There is a write up about taken the thing apart & wrapping tin-foil around some part of it to make them work but I was told the newer actuaters were the way to go. It's one of them jobs that took me close to an hour to do the 1st one & maybe 20 mins to do the other. It was worth it to me to buy the new ones & be done with it
Old Sun, February 26th, 2012, 08:33 PM
The door lock actuators use a thermal resistor circuit breaker. It's a safety feature to keep kids/dogs/cargo from burning the truck to the ground if the door lock switch is depressed too long. As the temperature of the circuit breaker goes up, so does the resistance. As resistance goes up, the current though the circuit goes down thus minimizing heat created in the circuit in the event of a short or a switch depressed for an excessive amount of time.
Over time, these resistive circuit breakers "wear out" electrically and limit current to the actuator motor windings even under normal (cool) situations. Yes, it is possible to disassemble the actuators and provide a parallel shunt across the circuit breaker but it's not adviseable due to safety reasons.
Unfortunately the only way I know of doing it properly is to replace the entire actuator in each door (which if you have a crewcab truck will cost you plenty).
Old Sun, February 26th, 2012, 10:19 PM
God & Guns
Thanks for the reply Cody. Is this something that would happen to all 4 doors at once? After I replaced the fuse, I was able to get the locks to attempt to actuate. But they all seemed like they wasn't getting enough juice, and each click of the button the juice seemed to decrease a little bit at a time...to all of the door locks.
I'm going to attempt to install a security system and it would be nice to have the door locks operating. Otherwise I wouldn't be worrying about it.
Old Sun, February 26th, 2012, 10:20 PM
God & Guns
Is there a wire I can check to see if it gets voltage when the lock/unlock button is pressed?
Old Sun, February 26th, 2012, 11:05 PM
The switches control the ground circuit of the lock actuator motors. The common scenario is that the actuators get weaker after the first button press and then begin to do less on subsequent presses.....once you let them rest for a few minutes, you can repeat the process.
It's not hard to test, but the best way to do it is to actually measure current flow through the circuit. Measuring voltage will only test the switches, power, and ground circuits.
It's not uncommon for all of the actuators to take a dump (my 01 CC was the same way). One fails and the others slowly follow until none of them work.
Old Mon, February 27th, 2012, 10:16 PM
winniety's Avatar
winniety winniety is offline
winniety is on a distinguished road
the simply way is change a new power lock
safy and fast
this situation is annoying
PSD #4 '95 loved it... '97 real POS...
2000 SC SB PSD E4OD 3.73 LS
door lock
2011 KR, loaded, Tuxedo Black/Adobe Best Yet!!
Old Sat, March 3rd, 2012, 10:44 AM
Lowdown89 Lowdown89 is offline
EVERYDAY HUSTLER
Lowdown89 is on a distinguished road
You can also pull the actuators and drill out the rivets and replace the little piece tht wears out with a piece of thin copper or something of the sort... That's what I did and my door locks one work like new now I'm sure if you hold the locks down something is gonna get hot and I voided some kinda safety feature but it was free and took about 2 hours start to finish
Old Sat, March 3rd, 2012, 10:47 AM
EVERYDAY HUSTLER
Here is a write up on how to fix them
Do-It-Yourself Door Lock Actuator Repair - Ford Powerstroke Diesel Forum
A lot of people use zip ties or something like that to out he cases back together we drilled out the holes and put in small stainless nuts and bolts and like I said it works great no sense in spending a ton on OEM actuators or buying the cheap ones that will wear out quickly
Old Sat, March 3rd, 2012, 12:14 PM
God & Guns
Thanks lowdown...gotta print that off. Id get a headache trying to read all that on my phone.
