Old Mon, March 30th, 2009, 12:43 PM
th3godf4th3r th3godf4th3r is offline
th3godf4th3r is on a distinguished road
Default Why am i not getting good MPG?
Hey everyone, i posted this over at f150online a couple days too but thought i would post here also
Well i just got home from a 300 mile trip.
anyway about 175 miles of the trip was flat and i had it at cruise control on 65
the other 175 were kinda hilly and going over one mountain pass and had it at cruise on about 75
by the time i pulled into my driveway, my truck computer said 15.2 mpg and my gryphon said 15.1
what im confused about is people like FishChris (on f150online) who said towing his boat he gets 16 mpg.
heres the modifications i have done to it
2008 Ford F-150 Lariat Supercrew 4x4
True Dual magnaflow exhaust with an X pipe
Gryphon programmer with custom tunes
33' BFG A/T's 18" XD monsters
K&N CAI
3.73 gears
City driving which is 95% of the time i only average about 12-12.5 mpg and never really get above that
i drive pretty conservatively too, no rabbit starts. I also do live in Seattle which has alot of hills but i would think i could get better than 12.5
now i didnt buy my truck to get good gas mileage but i just wish i could get some better mpg than i am getting
somebody said with my exhaust i probably lost some low end compression, this would hurt me going up the hills, is that true?
do you think i should try my custom towing tune? any other comments?
2008 White Ford F-150 Lariat Supercrew 4x4 | PHP Gryphon w/ Custom Tunes | 18" XD Monster's | 33" BFG A/T | AS Leveling Kit | Brandmotion iPod Adapter | 6000k H.I.D Lights | Line-X Bedliner | Weathertech Floorliners| True Dual Magnaflow Exhaust| K&N Cold Air Intake| Troyer Performance UD Pulleys
Old Mon, March 30th, 2009, 12:50 PM
I am sure Jack and others will jump in here too, but MPG reports are like fishing stories!!! (especially when the user's name is FishChris) So take it with a grain of salt. Tire rolling resistance will make a big difference. a highway tread Low rolling resistance tire could easily net +1 or more MPG's. Wind resistance is a big factor too. I'll see if I can find a graph to illustrate that and post it. Asphalt vs concrete highways will affect MPG too.
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
Old Mon, March 30th, 2009, 01:00 PM
well i did just change my tire size to 2541mm which it should be with 285/65/18 tires.
the programmer said it was at like 2742 or something
hmm i didnt know asphalt and concrete made a difference!
Old Mon, March 30th, 2009, 01:20 PM
Here is an in-depth article on MPG and tires. there are a couple of interesting diagrams on page 40 that show where energy losses occur in automobiles.. There is also reference to road surface effects on MPG
Tires and MPG
Minotaur user.
Old Mon, March 30th, 2009, 01:49 PM
Try using your custom tow tune.
But like Southpaw addresses there is a lot of different factors out there and they all add up for you or against you.
Take for instance:
Tire type.
Tire wieght.
Wheel weight.
Gearing.
Cai.
Exhaust.
Cats.
4x4.
Headers.
Trailing weight.
The list goes on.......
Old Mon, March 30th, 2009, 02:55 PM
Fuelly F150 MPG's
Is a good link to get more realistic MPG's
Minotaur user.
Old Mon, March 30th, 2009, 03:35 PM
Southpaw and Lars pretty much covered it. I know Fishchris' truck, because he did a TON of postings in the "Appearance Products" forum in f150Online when he was getting his truck.
The boat he pulls is very lightweight, something less than 1000# with the trailer. His truck is an SCab, not an SCrew, so it's somewhat lighter than ours. It's 2WD, not 4WD like ours. It has 17" wheels. I don't know what his gearing is, but I suspect it's lower than 3.73.
So, everything I know about his truck tells me he SHOULD be getting better gas mileage than we do.
I averaged about 15.5 mpg in just under 1400 miles on our last trip at 70-75 mph (hand calculated at each fillup). I get around 12.5-12.7 when we pull our 3600# trailer. My tires are 275/65-18 Goodyear Wrangler Silent Armors and they have a fairly conservative tread - I'm sure mine have less rolling resistance than yours.
Both you and I have more bells and whistles in our trucks than Fish has. For instance, we have climate control, and it's ALWAYS on in my truck. That consumes energy.
I don't trust either the Gryphon's or the truck's MPG displays. The truck's is always lower than the Gryphon's average numbers and my "hand calculated" results fall between the two.
One point - unless your loaded tire circumference is correct, your speed and odometer values will both be wrong. For my tires, I've subtracted 3% from the unloaded tire circumference. Using Bill's calculator, that corresponds to a 7% rubber squish (since the wheel doesn't squish). I don't know what your unloaded circumference is, but you might try entering a value that is 3% lower for the tire size. (A larger number shows up as higher speed and more distance driven per tire revolution - and, when the Gryphon's speed readout is correct, the dashboard speed will be 2 mph faster, but the odometer will be accurate).
Finally, each truck is an "individual". Some will simply perform better than others and there's not a whole lot we can do about it.
Two more posts appeared as I was writing this "book". The "fuelly", site was quite interesting, Southpaw. Looks like the trucks getting about 15 mpg are in the majority. And JWBFX4's remark on the tires is dead on!
Last edited by Jackpine; Mon, March 30th, 2009 at 03:42 PM. Reason: Two more posts to acknowledge
