Old Tue, April 21st, 2009, 06:19 PM
TJ05FX4 TJ05FX4 is offline
TJ05FX4 is on a distinguished road
Default Error During Firmware Update...Gryphon Not Functioning Now
I just got my Gryphon today from a F150online member and placed my order for my custom tunes. I was going to install the Gryphon in the truck and at least use it as a gauge monitor for the time being, but I thought I would update the Firmware first.
I installed everything successfully, connected the Gryphon and it started the updates. About halfway through it came up with an error message that was there about a second and disappeared.
Now when I plug in the Gryphon to the PC, the error message is.
Version ID Error
"Unable to determine Gryphon Version. The Gryphon may be in Run mode, is currently set as a Stock Writer, or the memory is corrupted. "
Now its not doing anything. It lights up when its plugged into the truck or USB, but it won't even display anything at this point. The lights come on and that's about it.
I emailed Bill, but I was hoping to maybe get a quicker answer here.
Thanks
Old Tue, April 21st, 2009, 07:24 PM
I would pm Bill on this one also include WHO you bought it from. It would also be a good idea to get your numbers in your user cp(serial and hex code).
Old Tue, April 21st, 2009, 08:22 PM
I don't have an answer for you, but I have some questions, and then some steps to try.
First, what version of Windows are you using? XP, Vista or 64-bit Vista? Vista has known issues with the Pegasus drivers and 64-bit Vista won't work at all. If it's ordinary Vista, make sure you follow the instructions in the Pegasus manual that work around its hangups.
Next, when you plug the Gryphon into the PC, what do you see in the status bar at the bottom of the Pegasus window? Does it say "connected"? Do you see a Serial Number (S/N) in the lower right corner of the status bar? It's normal for the Gryphon to simply light up at this point and do nothing else.
If it shows "connected" and displays a Serial Number, try updating the firmware again. This is Updates->Gryphon Update Manager. Update the firmware if you can.
It is highly unlikely that the Gryphon will run on your truck if it has custom tunes loaded. It won't like your HEX code. To get around this, update your calibrations also, that should return it to "stock". Once at stock, it should recognize YOUR truck's HEX code and it should perform as advertised.
The steps I've outlined will not hurt anything, so give them a try. If you still have "no joy", you WILL have to get Bill's help. Hopefully, this will get you going so Bill will have more time to work on your tunes! (And they are shut down for that very reason this entire week).
Old Tue, April 21st, 2009, 10:29 PM
Thanks for the suggestions thus far. I was thankfully able to get a phone call from Bill and he walked me through the process to get it corrected. He had to recalibrate it in some form. Somehow during the update the Gryphon lost some of its information and didn't reload it.
But thankfully its now in the truck and running fine I've updated earlier today my HEX and serial, so now its just a matter of waiting for the custom tunes
Old Sat, April 25th, 2009, 03:02 PM
Ballin STX Ballin STX is offline
Ballin STX is on a distinguished road
I am having the same issue and i cannot seem for bill to get back with me to help me.. i have sent him numerous email! How did you get in contact with him so quickley
Old Sat, April 25th, 2009, 03:15 PM
Time out! You bought a used Gryphon too? You tried to update the firmware using Pegasus and partway through there was an error? Now it won't connect to Pegasus (or your truck)?
If this is the case, and you've tried the steps I outlined for TJ05FX4 and it's still not working, try sending Bill or Corey a PM. It would also help if you would put your personal data (such as your name, your unit's serial number and so on) in your User CP.
