Old Mon, March 7th, 2022, 02:16 PM
madsenco madsenco is offline
madsenco is on a distinguished road
Default single shots wont idle
needing some help in a bad way, recently put a set of 180cc%100 nozzle single shots in a 02 SD, truck runs great other than im having an issue getting it to idle, as soon as she kicks off she starts loping real hard and wont stablize unless you feather the throttle a little, once its stabilized it idles just fine , did a data log and it looks like its bouncing from 100 to 0 on mass fuel desired, just looking for some direction if yall wouldnt mind
Old Mon, March 7th, 2022, 02:40 PM
Modified injectors, especially those with larger nozzles (80% or larger), require custom tuning to correct the overfueling at idle caused by the extra fuel.
Do you have a chip or programmer that you can use for custom tunes?
Old Mon, March 7th, 2022, 02:47 PM
yessir,I also got a few base files from you guys for those injectors, i spent about 8 hours the other day tweaking it and data logging and just cant seem to nail it on the head, not sure if i need too look at duty cycle or my pulse width
Old Mon, March 7th, 2022, 03:00 PM
Are you running the 180/100 files? Or the standard files for the stock injectors?
The 180/100 files should actually idle pretty well. We've used those for many years with very few issues.
Old Mon, March 7th, 2022, 03:24 PM
ive tried all three that i got and no change, truck came in for injectors and cups but started and ran just fine
Old Mon, March 7th, 2022, 03:25 PM
ive also put some miles on the truck as well to rule out air in the system
