2009 to 2014 F-150
Old Fri, January 23rd, 2009, 10:45 PM
Thanks, Bill - makes perfect sense to me. And, I can see how your A/F curves smoothly adopt that strategy, rather than having the sharp "bump" at 4500 rpm.
But, now I've started "thinking" again (which I know is dangerous). The stock curve seems to hold the A/F ratio near 14.08 (the ideal for E10). And, I have to imagine the older trucks like my 2005 and earlier tried to hold it at 14.64 (for REAL gas ), so did Ford put out a flash to the PCM to "adapt" them to E10 when it sort of became the "standard"? As I recall from the f150 forums, the 2004-2005s were already lean running when they came out. E10 would just make things worse, right?
Old Sat, January 24th, 2009, 01:00 AM
To some degree. Keep in mind that the vehicle tested was a FlexFuel vehicle and had the ethanol sensor. Also, don't forget that those are WOT runs. The fuel strategies are a little bit different at WOT than at cruise where 15+ AFR is not uncommon.
Old Sun, January 25th, 2009, 07:56 PM
chappy's Avatar
chappy chappy is offline
chappy is on a distinguished road
That is pretty Fricken sweet.nice job.
early 99 f250 powerstroke ddp stage 1's, php tuned, 6in 35's,tymer knock off,single stack,adrenaline and 05 f150 Custom tuned by PHP
Old Wed, January 28th, 2009, 11:23 AM
secondarychaos's Avatar
secondarychaos secondarychaos is offline
Tuner NON-extraordinaire
secondarychaos has a spectacular aura aboutsecondarychaos has a spectacular aura about
Really? I thought this was a recipe for disaster. I always heard how leaning a motor out could wreck any number of parts, most notably the pistons. is there any truth to this? is it only under certain conditions?
Originally Posted by Mabel Ostertoaster View Post
Not to mention the fact that the grants are ridiculous and you have to be in very specific categories to qualify - Male, between the ages of 41 and 42, who rides a unicycle to work, has a baby rhino for a pet, and only eats pork fried rice all day.
Old Wed, January 28th, 2009, 11:44 AM
At cruise, there's very little load on the engine. I imagine that's how you get away with a lean A/F setting.
Old Wed, January 28th, 2009, 01:55 PM
Exactly. Running a tad lean (lean being a relative term here) during light cruise (minimum load) is not uncommon for most auto manufacturers. In fact, I've seen as high as 15.8:1 under light cruise. Under acceleration or load, fuel curves will richen up as necessary to keep things safe.
Old Wed, January 28th, 2009, 06:35 PM
Ok, so it's Lean + Load conditions that can cause issues.
thanks for the clarification!
Old Wed, January 28th, 2009, 07:12 PM
Couldn't have said it better myself!
Old Thu, January 29th, 2009, 12:32 PM
AgentOrange's Avatar
AgentOrange AgentOrange is offline
AgentOrange is on a distinguished road
Bill,
I do not have a Gryphon yet, hopefully soon...that being said, because of the air intake mod I have, do you think it would be detrimental to my engine (stock 5.4 3v with stock air filter) to make WOT runs? Should I cap off the ram air section and just let it breathe through the fenderwell until I get a Gryphon?
I haven't made any WOT runs yet, and based upon your explanation of A/F ratios it's probably a good thing I haven't.
Thanks for any guidance.
Old Thu, January 29th, 2009, 01:00 PM
Originally Posted by AgentOrange View Post
Bill,
Let's see if I can get this right before Bill chimes in:
I think, because you've done no modifications to the intake system past the intake tube (the filter box and filter are all stock), you're not going to fool the MAF sensor into thinking there's less airflow than there really is. So, I don't think you have to worry about running lean.
But - and here I don't really have a clue how to proceed - at high speeds, your "ram" air intake is going to have a little bit of the effect of a blower (although I doubt it will be TOO significant). That COULD upset things a bit.
(BTW - the only reason I jumped in here was to test my understanding of this concern).
Tags
2009, dyno, f150, power, results, torque
