Hello there folks, I've been a stray the past few months, well big stuff has happened. Part of that big stuff is I traded in my old '04 XLT Supercab for a '07 Supercrew Lariat. Kept the wheels/tires and Gryphon. Of coarse returned the 04 to stock. I want to add it to the '07 but have some questions.
Firstly, what all will I need to do to get it changed over for the new truck in a '87 tune? Send in an application stating what I want? I already have the old programmer and all. Hex and Serial # available of coarse. Second, Should I do the minor performance modifications first? I am only planning a DWV intake mod and chopping the OEM Y pipe for a Magnaflow #10778 Y pipe which basically eliminates the restriction of the OEM pipe, and to run a single 3" pipe to a 3" Borla muffler and 2.5" tailpipes. I also plan to add on the 33"x12.5"/20 Mud Terrains I had on the old truck to this one but am kind of scared to for the rear end and transmissions sakes. The gears are 3.73 open, not LSD unfortunately, old truck was 3.73 LSD. Will it move fine? I also feel that aside of my 'hot doggin driving' as seen in some of my Youtube videos.. ( ) that the transmission in my old truck developed a minor slip. I don't plan to whoop on this truck and it has barely ever towed so I am hoping that the trans in this truck will handle 33s on 3.73s fine? I had heard that the 04/05 3v 5.4Ls were mated to a 'weaker' transmission than what is in the '06/'08 trucks, is this accurate? I am hoping so. Stock to stock, this 2007 Lariat seems A LOT quicker, actually very much, than how my 2004 felt, and almost equivalent to how smooth and quick it moved tuned on 33s. I have about figured out what I want in a tune for this one so I hope it will work.Advice for all of my question areas? Greatly appreciated. Also, are the tune return times about the same as they were in '09/'10? ( 1 month or so? ) And also how about adding an update for a modification, say I do exhaust and order the tune, 5 months later I do the DWV mod, will it cost me the price of a tune to update my file? And a couple pics of my new truck. ![]() ![]() ![]() ![]() Trade in day. ![]()
Appearance: Painted Headlamps/Fog lamps, 20% Tint, LED Reverse & Plate Lights Performance: 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips. Suspension: Bilstein 5100 Leveling Struts & Rear Shocks. 20"x9" KMC XD Monsters, 33x12.5 Toyo M/Ts |
Nice looking ride
All of the mods you listed can be done before or after your custom tune, they really aren't tune dependent ..... Here's the order form ....just list anything and everything.....no different than from before....>>>https://fs21.formsite.com/Power_Hung...m45/index.html
Right.....you keep the stock air box....so the transfer location remains the same
And, as long as you've restored the canned tunes to the Gryphon, [Updates]->[Gryphon Update Manager] in Pegasus (update both the firmware and calibrations) you can use the Gryphon in your new truck right away.
I'd recommend the Level 2 tune. - Jack
So the Level 2 tow tune will be safe for daily driving? Mostly is a canned tune for more low end energy correct me if I'm wrong?
Then you go to the Gryphon Update Manager and follow those steps. Level 2 is probably the safest if you keep your foot light. Rather than just thinking it is "boosting low end" it fuels a bit richer, good for generating torque in the lower rpms. You are completely correct, I just figured it'd be better to understand why. Any more detail and you'd have to ask Cody or Bill, they actually mess with that stuff.
I set it up in the Lariat tonight. Some odd reason I think it fit the trim of the XLT better, but the silver paint matches the Lariat trim at least, that bugged me just on the XLT grey but was much too subordinate to ever alter and the 20% tint helped shade it darker anyways. Well by guestimate mathematics, the richer fuel will help low end get the weight moving but should not be a full blown out race up to high rpms for the sakes of running rich? As I noted in the origin post I do not want to be any bit concerned of my trucks safety, some good economy numbers for my random elevation areas and the ability to quickly pass when need be, and of most importance the health of the transmission. What ever it takes to make it last and not suffer from 33s. This is a bit of what I will need to explain when sending for a custom file. I recall when I ran the trans only level 1 on the old truck not a thing felt different. Later when I filled up with 93 and set the level 3 timing to 1.5 wow did it sound very beastly on the start and drove excellent. Whenever I wanted it to move fast it went, however that isn't entirely my intentions with this truck. I'm just a little too worried about screwing something up this time around I guess, but the old truck was probably just a little bit of a lemon anyways.
In my 2005, I found the Level 2 canned tune gave me better gas mileage and gave me much improved passing performance. (Which was what I was looking for.)
I don't know that you need to be "light footed". Longshot, buddy, I'm not arguing, but why did you say that? It's my understanding that the canned tunes are completely safe for any "stock" truck (i.e., not blown, no aftermarket CAI, no long tube headers and/or no X/H pipe dual exhaust mods. - Jack |
