Correct the conditions were not present at stock or using the canned tunes only after receiving the custom tunes. the maf sensor is clean and so is the tb and it moves freely just like the stock one. i had my custom tunes wrote around the mods in my profile my truck is a 2008 F150screw 5.4 |
Or do a search on here. I too had this installed. Now its on my garage wall of shame. Hopefully Bill or Corey get some input in here. About what's going on. Lars
SENIOR MODERATOR--PTLA God doesn't have a Facebook but he's my friend. God doesn't have a twitter, but I follow him. Last edited by 88Racing; Mon, June 22nd, 2009 at 02:36 PM. |
Stryker, if you didn't notice the one reference to this in the link that Lars posted, the throttle body spacer seemed to give modest gains back when engines had carburetors. They seem to do nothing either pro or con for a fuel injected vehicle except, in some cases, cause noise.
I see them as an unnecessary complication that should not be used under the K.I.S.S. principle. My advice would also be to take it off. It really sounds to me like the TC on your truck is sensing load and is unlocking, then locking back up again. You could check for this of course if you monitored "Comm Gear" as one of your PIDs. I might help Bill fix the issue if you were able to either confirm or reject this hypothesis. - Jack
I am going to remove the TB spacer this weekend on everyones recommendation. didnt know they were so "hated" in a sense lol
The ONLY thing I ever noticed, as I've posted too many times, was a tendency for the transmission and TC to downshift/unlock too quickly under fairly minor load. This has been tamed by my adjusting the part throttle shiftpoints and TC lock/unlock points downwards. - Jack |
Once you insure that your tire size and gear ratio are still correct and have all the other settings to your liking, Go to the "Part Throttle Upshift/Downshift" and "Torque Converter Lock/Unlock" choices. These change the speed at which these events happen by a small amount. As I recall, the Up/Downshift points can be adjusted +/-2, +/-3, and +/-5 mph for each gear change. I wanted mine to change at a lower speed, so I adjusted all of them to the negative maximum. Supposedly, this can improve your fuel economy a bit by getting you into higher gears sooner and keeping you there longer. I just wanted to reduce the tendency of the transmission to downshift when I thought there was still a power reserve. I did the same thing with the Torque Converter Lock/Unlock points. These are a bit more aggressive and there are four of them (one for each gear). They can be adjusted +/-2, +/-3, +/-5 and +/-10. Again, I reset all of them to the negative maximum, hoping to keep the TC locked up longer. It seems to have helped. I don't get the overeager unlocking on the slightest incline that I used to have. Note these "Part Throttle" adjustments have no effect whatsoever on WOT shifts. And, since part throttle shift and TC change patterns depend on both speed and throttle position, just a little more throttle at a given speed is all it takes to cause a downshift or TC unlock if that is wanted. Hope this makes sense. - Jack |
