Old Mon, July 6th, 2009, 09:38 PM
20045.4x4 20045.4x4 is offline
20045.4x4 is on a distinguished road
thats an awsome link. Thanks!!
Old Mon, July 6th, 2009, 10:11 PM
it says I need a PCM (HEX) code. Whats that?
Old Mon, July 6th, 2009, 10:35 PM
also since I bought it used what happens if the previous owner still has his tune in it? Like if he took it out with it still in PERF tune or somthing?
Old Mon, July 6th, 2009, 11:27 PM
If you bought it used you are going to get an error if another stock tune is present. Someone's stock program is still on there. It may have to be re formatted using edges software.
Old Mon, July 6th, 2009, 11:56 PM
Lars is telling you the "real deal" here, but I sense you are not really familiar with programmers. If you are, then, sorry, I don't mean to "talk down" to you.
You bought an Edge used. The previous owner had to return the tune on his truck to "stock" (Level 0) before he shipped it to you or the programmer will not work on any other vehicle - period. This is one of the hazards you assume when you buy a used programmer - and it applies to all of them, not just the Edge.
Now, for a nominal fee, Edge and PHP can "unlock" such a programmer so that it can work on your vehicle. This simply adds to your purchase cost.
But, you may not need this. When you plugged the Edge into your truck, WITH THE IGNITION ALREADY ON, did you see the "hex" code? If you didn't, you probably have a locked programmer. If you did, unplug it and plug it in again so that you can write it down (the ignition has to be ON).
If the Edge tells you your HEX code, you will be able to program in any of the canned tunes it contains. You should really have an Edge manual to refer to, but a Gryphon manual will do as well. You can get it here: http://dygytalworld.ehost-services13...02004-2008.pdf You may want to see how the canned tunes work on your truck. I think you'll see a definite improvement.
But: Remember to set your "tune" back to Level 0 (stock) before you send the Edge in for conversion! The custom tunes will be even better than the canned tunes.
Hope this is making sense to you. Welcome to the world of programmers!
Old Tue, July 7th, 2009, 12:05 AM
Your %100 correct i'm useless when it comes to tuners and computers and stuff. I havent got the programmer yet i'll get it later this week. When I get it i'll plug it in and see what happens. Thanks a ton for the help
Old Tue, July 7th, 2009, 12:18 AM
Happy to help! About a year and a half ago, I was in your shoes. It was a real learning experience.
The good thing about this forum is, you are not going to be "bashed" for asking questions!
Old Mon, July 6th, 2009, 11:22 PM
It is a number 7 digits long with letters and numbers in it. Like this ABAB1A1B.HEX example only. Being you have the edge you might have to find it in the user menu. Sometimes it is the first thing you see when the gryphon is plugged in. I have never had the edge.
