Towing
Old Thu, July 16th, 2009, 01:34 PM
408F150 408F150 is offline
408F150 is on a distinguished road
Anti-Sway has saved me many, many time. With how tall toy haulers are (I think mine is 11' 6"?), wind and semi truck gusts will whip you like crazy. It also saved me one time when one of my 4 ratcheting straps I had my quads tied down with snapped. I had 2 400# quads sliding around the trailer and assumed it was the wind. I could feel the anti-sway fighting it, I don't even want to know how squirrelly it would have been without it.
Old Fri, July 17th, 2009, 12:42 PM
I think anti-sway is important insurance too, especially if you're towing a high profile trailer. That's a huge wind sail back there and it doesn't take too much in the way of sudden crosswinds to have it push you all over the place.
Old Sat, July 25th, 2009, 03:54 AM
TXWolf's Avatar
TXWolf TXWolf is offline
Native American Redneck
TXWolf is on a distinguished road
A question about the anti-sway bars ... When I pulled my new trailer from the RV dealer to the house, I'm assuming that the loud creaking sound that was going on was from the anti-sway bars? Is there any reason why I shouldn't put a little lithium grease on the bars, to cut down on the friction/noise?
http://dygytalworld.ehost-services139.com/forums/image.php?
2008 F150 Supercrew Lariat 4x4
5.4L - 4.88 Gears
PHP Gryphon Programmer - BDS 6" Lift - Magnaflow Dual Exhaust - JLT Ram Air Intake - 20" Pacer Ridgeline Rims with 35" Mickey Thompson Baja ATZs Tires - Westin BullBar with Driving Lights
Old Sat, July 25th, 2009, 06:37 AM
don't grease the anti sway bar as (most) use friction to control sway,
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
Old Sat, July 25th, 2009, 09:32 AM
zeuss zeuss is offline
zeuss is on a distinguished road
My equalizer bars would creak and there was a hole at the top for oil to be added, but like said before, sway control usually works off friction. The ones I had were Reese, but I think nowadays they are incorporating equalizer and sway in one setup. So be careful where you lube. Maybe talk to manufacturer.
2002 F250 CC A/T
33 BF Goodrich
Autometer Trans, Pyro & Boost on the pillar
Zoodad
PHP stock, 40,60,80,100, and whisper
Old Sat, July 25th, 2009, 09:39 AM
My Equil-i-zer brand hitch says it's OK to grease the friction surfaces. It says doing this is "optional" and will not diminish the sway control properties, and, it might quiet the hitch.
If you notice the pressure that's exerted on the brackets, I think that's what does the most for sway control.
But the noise IS kind of nerve wracking at first. Sounds like something is breaking, doesn't it?
Old Sat, July 25th, 2009, 08:45 PM
Depending on what type of anti-sway it is, the creaking will be normal. If it's a dual-cam anti-sway, it shouldn't be groaning too loudly. If it's a friction type anti sway (which 90% are), the groaning is the result of metal parts and friction pads under high tension sliding on each other. You can grease the sockets in your yoke that the bars rest in, but anything from the ball back can't be greased too heavily. If you over-lube any of the anti-sway stuff you're just de-frictioning your friction activated anti sway. There's 2 types of friction, static (grip when stationary) and kinetic (grip when moving). The friction the anti-sway relies on is kinetic friction. The part of the groaning that can eliminated comes from reducing the intensity of the force unleashed when switching from static to kinetic mode by lightly greasing the resting points of your sway system (where parts sit when going in a straight line). This gets them from resting to moving more smoothly but doesn't make the amount of grip on the surfaces suffer too much
Old Sat, July 25th, 2009, 09:08 PM
Right! Sounds like you have a fair grasp of Physics! Lubrication has to decrease the coefficient of friction, but I suspect the "force" component overshadows that by a great deal. (I would not want to have my finger between the bar and the "brackets". I think my finger would simply become "grease". )
