Old Sun, August 2nd, 2009, 03:20 PM
Skipping custom options will always revert back to the original tuned programs.
Now, when you go back into the custom options to make further changes, you need to scroll up click and do "Load Previous Settings" to reload the last changes you made in the custom options. Otherwise it starts with a clean slate on the options and you'll have to re-enter everything.
Old Sun, August 2nd, 2009, 04:13 PM
not you not you is offline
not you is on a distinguished road
Ok i go into customs options and go to timing and set the timing to 1.0 hit enter and go to prevous setting and the timing is set to what i set it to ? then i go to done and thats being downloaded to the pcm or when i set the timing and put 1,0 in its already set ? now how do i know where the timing is at its still not coming up to where i set it at im lost .
Old Sun, August 2nd, 2009, 04:16 PM
I figured it out and got it to save seen a little difference on 1.0 should i bump it up more or keep it at 1.0 you suggested go up to 2.0 but i think i might be pushing it whats your opinion on that thanks Shawn
Old Sun, August 2nd, 2009, 08:32 PM
It's not the best recommendation, but you could push until you either hear a little pinging on hard acceleration or you don't feel any more power difference. On the dyno, the lack of power gain would be more readily apparent. As for the pinging, the knock sensor should pull timing out at the first sign of it but you should still hear a couple ticks before the PCM reacts. If you've hit this point, back off at least 1 degree, if not 2, and call it good. Remember, if you get poor quality fuel you may get pinging on a tune that would otherwise run fine.
Old Mon, August 3rd, 2009, 08:08 PM
THanks for the info but i am not going anymore if its not recommended its not for me . I will just keep it at 1.0 and see how it does i see a big improvement already driving back and fourth from work. thanks for the tech support i know your busy and Im thankful for the help Shawn
Old Mon, August 3rd, 2009, 08:48 PM
And Shawn -
If you EVER need to "reload" your tune (maybe after restoring it from Level 0) if you had to take your truck to a dealer, remember:
To get the "customization" you created for your tune you will HAVE to "open" the "Custom Options Menu"! If you don't do this, the tune will be loaded with all the parameters that Bill set in your tune (which are probably perfect) or that came with the "canned" tune.
But, as soon as you do this, virtually every "customized" setting returns to "stock" or to some "placeholder value"! And, now you're worse off than you would have been if you 'd just skipped "Custom Options" altogether!
To recover all those values you've grown to know and love, the very first thing you MUST do upon opening the Custom Options Menu is to scroll to "Reload Previous Settings" and hit <Enter> there! At this point, you're back to the settings you had in the PCM the last time you entered a tune.
If you're happy there, just scroll to "Done" and hit <Enter>.
Old Tue, August 4th, 2009, 08:09 PM
Ok im taking everybodies advice and putting it to what Bill set it at that way i dont screw it up .I going to put shell 87 octane in it on friday (going to Jersey from N Carolina for the week )to see how it does and will not touch anything on it but thanks for the info Shawn
