Towing
Old Thu, August 6th, 2009, 08:04 PM
Originally Posted by orygunf150 View Post
Firstly, to diesel rookie: I use the Podigy P3, a little spendy but I love it. It really needs to be at or close to eye level to see the display clearly leading to my question: can I mount this controller on top of my gryphon? Anyone know if this would cause any interference with either devices? The P3 says not to use cell phones or two way radios within 12" of it, but no mention of a tuner, car stereo or other electronics. Any other mounting area suggestions would be appreciated also.
I'm only guessing, but I'd advise against it. Do you really need to watch the display that much? I had to see mine, of course when I was adjusting it, and I glance at it now and then to confirm it's working, but mostly I just ignore it.
I have to move a bit to see it when driving - the display is hidden right behind the steering wheel down low on the right side of the steering column. But, I can tilt the wheel down for adjusting and otherwise just glance around it.
See the comment in the other thread about not running the wiring to the controller parallel to the OBDII cable from the Gryphon due to interference problems too.
