Old Wed, August 19th, 2009, 04:20 PM
Originally Posted by Rustler View Post
One last thing, the custom tune is spoda replace level 1. When I do get the custom tune will that wipe out the changes I've made to level 2 tow? Or do I simply select level 2 then use reload previous settings.
Thanks...r
When you get your custom tune(s). That process might eliminate the previous settings stored in the gryphon's memory?
If you have done extensive changes you might want to writethem down before downloading the custom.
If you have altered shift strategies on the canned tunes do not try them on the custom tune.
