| Towing This forum is specifically for questions, comments, or ideas about towing with your vehicle. |
I'm guessing that you have the 5.4 right? Many of the power curves I've seen show that the engine's peak torque is somewhere around 3000, after that it starts dropping off(slowly though). And yes I admit I could be a little off on this.
Also do you pull with O/D off? Some people say to not tow in O/D but my dad and many others around here have always used it and wont be convinced otherwise. My dad's truck has over 150K and he has had trouble one time but thats because he forgot he had a heavy trailer hooked up and punched it at a light. All that did was throw a code, after clearing that at a local shop it hasn't had any issues what so ever. And that is the only time that truck has ever been at an auto shop. Another thing, all of the hot rodding auto guys I know swear by Royal purple and their trucks and tranny's have been pushed extremely hard and are still going. just my $.02 PS: txwolf, how'd ya like pedernales falls state park? Haha, Txwolf ignore this, didn't see you had a separate post.
I usually have OD off while towing unless im heading down a hill or something (being in 3rd seems to slow the truck down). I cant see how your truck can pull that 36' trailer, have the TFT hit 200+ and still maintain a good speed. My truck just cant seem to do that.
I wonder if your transmission is "slipping" under load and with the fluid hot? Is it still under warranty? If so, set it back to stock, remove the Gryphon and take it to your dealer. I think they may need to "look" at it.
I think I'd do this even if the truck is out of warranty. This doesn't sound like something I'd like to see continue, because it could be an early sign of damage. You should NOT be having problems pulling a 5000# load. You'll certainly know it's there, but the truck was designed to do this task. - Jack |
I'd sure give it a try. The more I think about your symptoms, the more it smells to me like early indications of a transmission problem.
- Jack |
I'm with Jack ... I'd take it in for service. You own a TRUCK, and it's made to haul stuff!
If you're not able to pull a trailer that is well within the limits of what Ford says it can tow, it needs to be fixed. Plain and simple.
2008 F150 Supercrew Lariat 4x4 5.4L - 4.88 Gears PHP Gryphon Programmer - BDS 6" Lift - Magnaflow Dual Exhaust - JLT Ram Air Intake - 20" Pacer Ridgeline Rims with 35" Mickey Thompson Baja ATZs Tires - Westin BullBar with Driving Lights |
Alright, next time I take it in for service Ill see if they will look at the tranny.
thanks all |
