1997 to 2003 F-150
Old Fri, September 18th, 2009, 12:23 PM
RobbyMartin RobbyMartin is offline
RobbyMartin is on a distinguished road
Originally Posted by fordkindaguy View Post
I have an 02 4.6L and did notice some power gain but it could be because i also have a flowmaster cat back which allows a little better flow. The gryphon will tune your truck for the extra air amount coming in so it can put in more gas, more air+more gas= more fun
I like the more fun part but I really don't like the more gas I'll be using. I think I'll keek the stock intake and TB and sell off the aftermarket parts. I'm hearing good things about pulleys so I'm going to add those.
Old Fri, September 18th, 2009, 12:41 PM
Just so there is no confusion. Intakes in my world are the part that bolts to the heads. Other people call them intake manifolds.
Now Cold Air Intakes that come before the TB, I and others just call them cai.
Old Fri, September 18th, 2009, 01:32 PM
I am 100% sure I got a gas mileage boost from doing the "gotts" style mod to the stock intake. I can't really explain why this should be except that possibly I get a better A/F mixture at near WOT which in turn gives me better power shortening the time I have to be in that state?
Anyway, I know before the intake mod, I could get 15.5 mpg at 55-60 mph. Anything faster and the mileage dropped. Now I get 15.5 at 70-75, and am above 16.0 at 55-60.
Old Fri, September 18th, 2009, 03:08 PM
fordkindaguy's Avatar
fordkindaguy fordkindaguy is offline
Wanna go fast
fordkindaguy is on a distinguished road
depends on how you drive, it only will pull in more gas if you're on wot otherwise i believe people are claiming higher gas mileage due to changing standard shift points and that good stuff
Old Sun, September 20th, 2009, 04:47 AM
I didn't see if it was mentioned, but one thing that is a common problem is a moderately lean condition caused by using a CAI in conjunction with Programmer that wasn't set up for the inherent lean condition the CAI will normally cause. This results in poor throttle response and poor low RPM power. The canned tuning on the Gryphon will likely cause the same problems until you go with some custom tuning.
Old Sun, September 20th, 2009, 06:29 AM
I wasn't going to mention the "blanket response" for the cai being lean due to the year of vehicle. But it most definately could be possible. The other thing is a "small" vacuum leak.
To the OP does the idle dip when brakes applied?
Old Sun, September 20th, 2009, 11:23 AM
No idle dip at all. Normal idle in all situations.
I've heard before that CAI weren't good with programmers.
Old Sun, September 20th, 2009, 11:37 AM
Bill, I'm glad you responded. Thanks! I've heard before about the CAI/Programmer combo not working well. I have little low end/low RPM power. Power in the middle and higher RPM range is good for the 4.6L except the lag when it downshifts for passing.
Questions...I'm going to purchase the Gryphon but I'd like to know what would be best with a custom tune for my '02 4.6L. A Gotts intake mod or the Airaid intake I currently have installed? I live in HOT Southern California so I don't know if that makes a difference with your tunes. Stock TB or a BBK 75mm TB that I also currently have (not installed)? I'm also installing underdrive pulleys before I input to tune so also consider that.
Old Tue, September 22nd, 2009, 10:37 AM
On the F-150, the Gott's/Snorkel mod seems to work just as well as any commercial CAI kits. At least dyno results haven't indicated any appreciable difference. Not that there's really anything negative about the CAI so if you've got one already it's fine.
Newer trucks haven't seen any benefit to running a throttle body, but older trucks often see a moderate gain in mid to upper RPM performance in there area of about 5 to 8 HP.
Underdrive pulleys will require a small idle change (usually 50 RPM or so) to help keep the alternator charging correctly at idle.
In regards to air/fuel ratio and performance, peak torque and peak HP occur at different ratios with torque coming in about 11.25:1 to 11.6:1 and HP coming in around 12.25:1. If the fuel curves aren't correctly adjusted to meet the demands for the specific load/RPM, performance can suffer significantly.
I hope this makes sense.
Old Tue, September 22nd, 2009, 04:05 PM
I hope this makes sense.[/QUOTE]
This is the only part I didn't comprehend but not sure that I need to. I just want you to do your MAGIC so I can pop a wheelie...haha, just kidding.
Thanks for the input. I know what I'm going to do as far as the mods go .
