1997 to 2003 F-150
Old Sun, September 20th, 2009, 06:29 AM
I didn't see if it was mentioned, but one thing that is a common problem is a moderately lean condition caused by using a CAI in conjunction with Programmer that wasn't set up for the inherent lean condition the CAI will normally cause. This results in poor throttle response and poor low RPM power. The canned tuning on the Gryphon will likely cause the same problems until you go with some custom tuning.
I wasn't going to mention the "blanket response" for the cai being lean due to the year of vehicle. But it most definately could be possible. The other thing is a "small" vacuum leak.
To the OP does the idle dip when brakes applied?
Old Sun, September 20th, 2009, 11:23 AM
RobbyMartin RobbyMartin is offline
RobbyMartin is on a distinguished road
No idle dip at all. Normal idle in all situations.
I've heard before that CAI weren't good with programmers.
