Old Wed, January 14th, 2009, 11:44 PM
th3godf4th3r th3godf4th3r is offline
th3godf4th3r is on a distinguished road
oh and another thing, i dont have a load previous settings option after i click on "custom options"
however when i went to tire size, it went to a screen saying something about that it couldnt be done or something, ill try it again tomorrow and write it down if it happens again
but then it froze.
ill give it another shot tomorrow
2008 White Ford F-150 Lariat Supercrew 4x4 | PHP Gryphon w/ Custom Tunes | 18" XD Monster's | 33" BFG A/T | AS Leveling Kit | Brandmotion iPod Adapter | 6000k H.I.D Lights | Line-X Bedliner | Weathertech Floorliners| True Dual Magnaflow Exhaust| K&N Cold Air Intake| Troyer Performance UD Pulleys
Old Thu, January 15th, 2009, 12:02 AM
but then it froze.
The "Load Previous Settings" is at the *Bottom* of the list. I know, it's a dumb place but that's the way they had to handle the menuing to make it dynamic. Go figure.
I am not certain as to why the Custom Option for the tire size didn't work, or even worse why it froze up. Give me a call when you have time and we can walk through everything and see what exactly is going on.
Keep in mind that you do NOT want to do Custom Options until you have completed a full programming session. It is a bug in the firmware that allows you to actually select Custom Options without first reading a valid stock file from the PCM. If you had already done a programming session, then this doesn't apply to you, but if you didn't then it might be responsible for why the unit froze.
As for break in period... do you mean the engine? In most cases, you should let the engine break in for about 3000-5000 miles, or basically the first oil change.
Hope this helps.
Old Thu, January 15th, 2009, 01:01 AM
i know the standard break in, im at 7200 miles
i just was wondering if there was any after you installed the custom tunes.
idk im probably just talking stupid
but oh well
ok well i will go have a look tomorrow and let you know
