Old Fri, November 13th, 2009, 08:29 PM
Just shows how different trucks are like different people. No two will ever be exactly alike. But, I agree, it's kinda weird how they could be "opposite". I should probably try bumping the timing again now that I have custom tunes. Possibly, I'd get different, and better results.
Haha, I bet it can drive Bill a little crazy because he can never be 100% sure how a truck will react.
Originally Posted by Dfishrmn View Post
I have played with the timing a bit to see if there is a benefit. At +.25 it seemed peppier but less torque. Also had an increase in MPG (this was when I was still running the AC constantly). Tried +.50 but that almost seemed to erase any benefit. I am now running it at the 87 custom performance +0without the AC mostly and mileage is about the same as +.25 with the AC on. I like the way the truck feels at +0 better than with advanced timing. It just seems to pull harder. I'm not a racer, just normal mixed city/highway with light hauling and towing. I will try it again at +.25 now with the cooler weather and see if it makes a difference.
Also my idle seemed to smooth out at +.25, now at +0 it is slightly rough at times.
Thanks for the input, I think ethanol may be here for a while and this may help sort out if we can tweek things to better advantage.
^That is very similar to what was going on with my truck. Haha, you'd think that since they are machines off of an assembly line that they would all be the same. Sure is strange. But I guess it's those quirks that keeps Bill in business.
Old Fri, November 13th, 2009, 08:44 PM
Nope, two different machines off an assembly line will never perform the same, even if they are the same model, production run, etc.
I used to see this in aircraft. Each one had its distinct personality. The little tiny differences in tolerances and other production differences are enough to make fairly big changes in performance. I guess that's why a race car is "hand-tuned", from nose to tail.
Old Fri, November 13th, 2009, 09:18 PM
Haha, but back to topic there are some automotive items that I do like to be quirky--gas pumps. I remember one in New Braunfels a long time ago that would keep gas dripping even after the handle was let go. I guess it siphoned or something, but they've probably fixed it by now. I found one over where I'm at but it doesn't drip fast enough to be worth sitting there. ...seems like thats is the only time you get your money's worth. lol
Old Sat, November 14th, 2009, 10:51 AM
That'd be cool, free gas! I've seen a couple that didn't shutoff when the tank was full. That's a mess! And, a couple that allowed the previous guy to set the nozzle to on so that the next poor slob (me in this case) got a hose that started delivering gas just as soon as the pump was turned on (before putting the nozzle in the filler pipe).
I guess I'm happiest when the things work the way they're supposed to.
