Old Thu, November 26th, 2009, 08:58 PM
I just had my truck out on the freeway today with a few little hills I don't think I went over 1100F EGT's to reach or maintain 70ish with 9500lbs of bobcat and trailer even up the few hills on the fwy. that was on 40HP tow tune. but never had to floor it either, which would probably upped the EGT"s pretty quick
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
Old Thu, November 26th, 2009, 09:13 PM
This is a slightly doctored quote made by Dan (Kwikkordead from FTE) from PHP's testimonial page:
Originally Posted by Dan
I just returned from a trip with my 1999.5 F-550 pulling a Cedar Creek 36 RLTS. Total vehicle weight: around 24,000 lb. 7.3 4x4 ZF6 with 4.88 rear axle. 2500 rpm @ 70 mph in OD. I was running with a Diablo Predator before and was forced to return the truck to stock tune just to tow the trailer because the EGT would easily hit 1400 degrees on any hill, even using thier mildest Tow/Safe tunes.
After installing the chip and pulling the trailer, I found that on the 25hp Heavy Tow, the engine would pull the trailer up any hill up to about 4-5% grade in OD without having to shift down.
The turbo would simply spool up and the EGT's would not go over 1100 degrees - cooler by 100 degrees over the stock tune. It was very surprising to me how much better the engine sounded and ran as well. Bill knows his stuff and if I ever have a need for a another chip on a different truck I will not consider any other vendor. VERY satisified customer.
Superchips, Edge, and Diablosport all claim an EGT safe tow program on the lowest setting and I have yet to personally see an actual "safe" EGT from two of them while towing...even 6K lbs that should be easy on EGT.
I hope this helps.
Old Wed, March 28th, 2012, 12:35 PM
ManBearPig ManBearPig is offline
ManBearPig is on a distinguished road
I know this is an old thread but I have a similar question.
I have a Superchips 1705 and am wondering what kind of raw power increase a chip with the standard settings would net for me. I have a manual trans so shifting is not a concern.
I have previous experience with Tony Wildman's tunes on a different truck. Are the PHP tunes comparable in feel?
Old Wed, April 4th, 2012, 12:45 AM
Night and day difference vs the 1705 I ran one for awhile.. even with the standard trans you should notice a much more noticeable power difference..
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
Old Wed, April 4th, 2012, 11:06 PM
Hoverp Hoverp is offline
Hoverp is on a distinguished road
Yep! Night and day over the 1705. I ran for one for years on my 1999.5, it was ok, but now I just installed the PHP tunes and it is literally night and day difference for the better., shifting, and power are immensely better. Eggs are very modest for the amount of power derived from the programming.
Best 300 $ ie spent on the truck.
I kept my 1705 tuner.....but now it's just to read a code if I ever pop one.
Patrick
1999.5, F350 longbed 4x4, 7.3, auto
Tymar intake
4" turbo back Hushpower exhaust
FRX fuel rail crossover
PHP Phoenix chip
Stock,40tow,65tow,80dd, whisper, 120 race.
