  #14
Old Tue, December 8th, 2009, 08:20 AM
I don't think your "set them all to "0". " idea will work out too well.
You have to "think" like the PCM.
Since you don't have an AIH relay anymore, the PCM sees that there is no input when it is actually commanded on (proof that the AIH relay circuit is working). You need to either set the on-time to "0" (which for now I will assume is "MAIH_ON_MAX") so the PCM doesn't turn on the AIH thus it can't run the monitor diagnostic OR you need to change the diagnostic parameter to reflect that there won't be an input voltage to the PCM when it is commanded on but I haven't seen anything in the top section of the parameters list to reflect AIH monitor input values.
Good luck.
