ok sounds good. did u replace with stock ones or upgraded to something different? I know its a different topic but just curious if they make a big difference.
2.5 HBS Level Kit, Magnaflow SI/DO, PHP Gryphon, AEM BruteForce |
Some other have tried champions or autolites and ended up doing them again after 10k-20k.
Will do! Thanks 88.
i never thought of this before, would this effect my new motor in my truck that i swapped since it is a 2003 5.4l 2v ? it had originally the cop ignition black boots before i swapped to coil system. i have not changed them as of yet since i am waiting for my tunes first. But shortly there after this is since i do not know when or if they were ever changed in this vehicle originally. it had only 38,000 km on engine when i bought it a month ago
Last edited by 88Racing; Sat, December 12th, 2009 at 11:40 PM. Reason: Hit edit by accident |
That's why this is posted in the 04-08 section. If you have a 5.4 2v then this tsb does not apply. You just have to make sure you torque yours right so they don't loosen up and pop out.
Paying for plug extraction. Or. Paying for the install of time serts.
ok great thanks for the heads up with the torque, its usually 25lbs right?
On your applicaction 03 5.4 2V that sounds about right.
